Tiger Chat For owners and riders of Hinckley Tigers: 885, 885i, 955i and 1050i
Old 07-20-2005   #1 (permalink)
wiko
hi folks,noticed when cleaning the bike on the stand yesterday that when ticking over in neutral the wheel was spinning, until i pulled in the clutch then it stopped. done 4000 miles this year so i will be doing a oil and filter change soon will this help?
Old 07-20-2005   #2 (permalink)
BigStripey's Avatar
Wiko,
Don't worry about that, that is fairly normal. Not sure what causes it?, perhaps it is just a centrifugal effect from the clutch plates or something?.
Did you try and stop the wheel with your hand or boot?, if so, was there much resistance or did it stop straight away?
I doubt that changing the oil will make any difference......
Robbie / Winger, you are both engineers, do you know what this phenomena is ??
Big Stripey
BigStripey is offline   Reply With Quote
Old 07-20-2005   #3 (permalink)
wiko
hi big, i used my hand but it took a little muscle though. i will do oil change and see what happens though. Thanks for the quick reply. :upthumb:
Old 07-20-2005   #4 (permalink)
blacktiger's Avatar
It's oil drag in yer gearbox that does this. Bit like a torque converter in an auto-box.
Nothing to worry about. Does it less when the oil is hot. Makes oiling yer chain easier.
H
'02 Tiger955i in black.
Old 07-20-2005   #5 (permalink)
wiko
good tip,means i dont have to hassle the wife to spin the wheel. she said how can i ever thank this blacktiger chappy :-D :-D :-D :wink:
Old 07-20-2005   #6 (permalink)
kpresco2
Mine does this as well, when it is cold - but the wheel stops spinning once she gets warm.
As blacktiger said, it's just oil drag, and it certainly does make oiling the chain easier....
Ken
[ This message was edited by: kpresco2 on 2005-07-20 20:09 ]
Old 07-21-2005   #7 (permalink)
I think every bike I've had has done this. It's not a problem or a sign of a future defect.
Like everyone says, it makes greasing the chain easier, but I'm an idle bleeder so I've got a Scott-oiler. :hammer:
Mick
Spudgun is offline   Reply With Quote
Tick Tick Tick SpeedMaster 2007 VTXED Twins Technical Talk 2 09-25-2007 04:32 PM
fuel tank bolt spinning - T140V jnutter Classic, Vintage & Veteran 5 04-06-2007 04:39 PM
Spinning the rear wheel on Sprint johnshumpert Sprint Forum 12 07-07-2006 03:11 PM
siezed bolt/spinning nut jaben Hinckley Classic Triples 2 01-24-2006 01:04 PM
Tick-Tick/Dick or...how's your rearend? BIKERDICK The Rocket Science Forum 9 07-28-2005 01:07 PM
