Trident-Exhausts.comAdvanstarMotorcycleShowsBikeBandit
Tiger Chat For owners and riders of Hinckley Tigers: 885, 885i, 955i and 1050i
BikeBandit
Old 07-17-2005   #1 (permalink)
Just a quick enquiry 'cos my bike isn't where I live, so I can't just go look.........is it a front fairing off jobby to change the headlight bulbs for some of those Blue Vision numbers or can it be managed while all is intact?
Thanks in advance.
Gizmo is offline   Reply With Quote
Old 07-17-2005   #2 (permalink)
I think it is.
I took of the fairing to change the bulbs, but it really is simple.
Remove the screen with the four screws.
Remove the black indicator mountings, 2 torx screws on the outside and 1 hex head on the inside (I think).
Remove the the 2 hex bolts behind the screen and of the fairing comes.
You can then access the headlights, but I seem to remember having to unbolt them as well to get to the bulbs.
Chris
Arrybash is offline   Reply With Quote
Old 07-17-2005   #3 (permalink)
Thanks for the info.
Sounds like a 12000 mile service to me what with all that Torx and Hex et al. Still, that's why Im not a technician (new word for mechanic, apparently, and the reason why servicing is soooooo expensive. Same knowledge - trendy name = more expensive - EASY ! A good one is worth their weight in gold, a bad one.....well).
Might give it a go when I've got a few days free.
TTFN.
Old 07-17-2005   #4 (permalink)
Hi Gizmo,
I changed my 955 Tiger headlight bulbs without removing the fairing. Just reached in, pulled the rubber rear cap off. Unclipped the bulb holder, removed the bulbs, unplugged the wires and reversed the procedure. The only fiddly bit is getting the bulbs plugged into the wiring. A torch helped here but it was not too hard.
Timtiger is offline   Reply With Quote
Sprint ST Bulb upgrade PaulHammo Sprint Forum 8 05-10-2007 03:22 AM
Headlight bulb wiring stevesrs Sprint Forum 0 11-19-2006 02:58 PM
05+ headlight bulb? SR1 Sprint Forum 16 11-15-2006 11:00 AM
The little bulb in the headlight? FelixLeiter Speed Triple Forum 5 03-05-2006 08:05 PM
S4 headlight bulb Modifications & Workshop Talk 2 03-17-2004 04:22 PM
