carb vent
my 96 tiger didnt have the vent line(s).
it just had the carb (float bowl) vents open at the nipples. i put a lengthof clear plastic hose on each, running them up about 5". the purpose was to keep dirt and dust out of the carb float bowl chamber.
you will see where your hose connects to the carb.
the there should be another hose one carb over.
if not, you may wish to add one.
the carb float bowls have to be vented to atmosphere, (or airbox if intake is ram air fed) otherwise they would starve for air (pressure) and no fuel would make it thru the jet hole openings.
check out kevin camerons, sportbike tuning book if you want more info.
