Originally Posted by pineygroveshop
What symptoms would you get to alert you the stator is bad? Easy to diagnose? Common?
Battery stopped charging, check engine light went on, unable to start bike (same symptom as dead battery). Had to test battery output to determine that was not the problem. That left the stator as cause.
