shorter kick stand - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger Chat For owners and riders of Hinckley Tigers: 800, 800XC, 885i, 900, 955i, 1050i, 1200
Old 10-13-2009, 08:50 PM   #1 (permalink)
Newbie
shorter kick stand
lowerd my tiger but kick stand to long any idea be sides cuting and rewelding
jeffu is offline   Reply With Quote
Old 10-13-2009, 11:00 PM   #2 (permalink)
Favourite Bike: '03 T-100 & '08Tiger1050
One could simply heat and bend the side-stand more so it contacts the ground further from the bike--this will effectively shorten the side-stand. However, when the side-stand is "up" it will stick out to the side more, so look at this part of the remedy to see if it will work for you. To bend the side-stand, I would remove it and put it in a vise, heat it with a torch and bend it where the foot is about 1" further away from where it is stock.
Good luck,
Larry
Old 10-14-2009, 02:33 AM   #3 (permalink)
Favourite Bike: Maggie, my 1999 Tiger
TucsonBill's Avatar
Other Motorcycle: Jack, my 2001 Tiger
Extra Motorcycle: Shaza, my 2000 Trophy
I don't get it. My 2001 is lowered about 2" front and rear and the kickstand is fine. I wouldn't feel comfortable bending the stand, I can see that failing. If you want it to go further out, just grind the stop off a bit on the upper end of the stand. The foot won't sit flat on the ground, but it won't weaken the stand itself.
William Fee
Iron Butt #26777
Tucson, Arizona
TucsonBill is offline   Reply With Quote
Old 10-14-2009, 04:56 AM   #4 (permalink)
Put on a Happy face.
I shortened mine when i went to a 17" front wheel,it's no big deal,go to any welder/metal work company,i used the maintenance dept in the company i used to work for!!,get them to take the plate off the bottom and shorten the stem,don't go mad cutting loads off you'd be amazed how little needs taking off.
I cheated a little,just in case!! bought a secondhand sidestand,but it worked fine,i guess it's been on the bike 6/7 year now,oh and of course had to re-paint it.
winger is offline   Reply With Quote
Old 10-14-2009, 06:16 PM   #5 (permalink)
Newbie
not made of iron donot think can bend with out breaking
Old 10-14-2009, 10:24 PM   #6 (permalink)
Sorry guys, didn't realize you were talking about the Tigers prior to the 1050. That stand is made of steel and can be bent, cut, shortened, welded, etc.
Have a good day,
Larry
Old 10-15-2009, 04:47 AM   #7 (permalink)
One shortened stand!!
Old 10-20-2009, 02:34 PM   #8 (permalink)
Newbie
This game will be awesome. I had a blast playing the demo.
thiquigli is offline   Reply With Quote
Lowering/shorter side stand Juz Street Triple Forum 6 04-27-2009 03:02 AM
shorter side stand (kick stand) ? TriumphTT_2 Triumph SuperSports 6 06-07-2007 07:04 PM
I need a shorter side and centre stand Bikermouse Tiger Mods & Bolt-Ons (archive) 3 05-01-2007 12:05 AM
shorter side stand bretzg Tiger Mods & Bolt-Ons (archive) 1 12-20-2005 11:18 AM
Kick Stand vs. Center Stand Tooth Maintenance & Workshop Talk 9 10-19-2005 10:02 AM
