Valve Adjustment Help - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!New BonnevilleMotorcycle.com
Tiger Chat For owners and riders of Hinckley Tigers: 800, 800XC, 885i, 900, 955i, 1050i, 1200
Old 09-25-2009, 09:28 AM   #1 (permalink)
Favourite Bike: 06 Tiger
Guys,
I have an 06 Tiger w/19K miles and it needs a valve adjustment! I would take it to the local dealer but I just lost my job and can't spend the money.
I need advice and a valve shim tool and advice; can anyone offer some help?
Fe Man is offline   Reply With Quote
Old 09-25-2009, 04:09 PM   #2 (permalink)
Favourite Bike: 2006 Tiger '955
Fe Man,
It's a relatively easy job if you are mechanically minded. Have you got the Haynes Manual and are you mechanically minded ??
It can be done without the shim tool as well if you are prepared to take the cam shafts off ??
Safe riding.
Regards,
Graeme.
Bike: Tiger 955 (2006)
Tiger-G is online now   Reply With Quote
Old 10-01-2009, 06:04 AM   #3 (permalink)
Favourite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1961 BSA Golden Flash
There's a good shim tool available from Mustang of this parish (and elsewhere).
Ian
2004 Tiger 955i
1961 BSA A10 Golden Flash.
iansoady is offline   Reply With Quote
Old 10-01-2009, 06:39 AM   #4 (permalink)
blacktiger's Avatar
Originally Posted by graeme View Post
Fe Man,
If your shims are on top of the buckets as my '02 has, you don't need to remove the cams. You can get the shims out by removing the bearing caps and lifting the cams slightly without disturbing the cam chain.
Good luck with the job hunting.
You only live once, so enjoy it.
'02 Tiger955i in black.65000 miles.
http://s396.photobucket.com/albums/p...55tiger/TIGER/
'12 Tiger800XC in black. 11500 miles.
blacktiger is online now   Reply With Quote
Old 04-15-2010, 02:47 PM   #5 (permalink)
Favourite Bike: 2005 955I
Does this mean you can change your shim's without the valve adjustment tool ? 05 955I
day955i is offline   Reply With Quote
Old 04-16-2010, 03:18 AM   #6 (permalink)
Jonny955's Avatar
All that my valve adjustment tool does is hold down the bucket so that the shims can be slipped out/in. It saves lifting the cams.
At 19K miles it is possible that your valves clearances are still within service limits. I checked mune at 14K and they were all OK. If you have the skill and the time, it will cost you nothing to check (well, maybe some sealant for the cam cover which I forgot about)
Jon
Jonny955 is offline   Reply With Quote
Old 04-16-2010, 05:42 AM   #7 (permalink)
blacktiger's Avatar
Yes it does.
Valve adjustment bueller Hinckley Classic Triples 18 06-21-2011 06:37 PM
valve adjustment? tri955i Daytona Deliberations 5 06-29-2009 11:34 AM
First Valve Adjustment FlatFourOne Twins Talk 22 11-30-2007 03:17 PM
Valve adjustment boocat Tiger Workshop (archive) 3 05-07-2006 05:39 PM
Valve adjustment? qc415 Speed Triple Forum 3 06-30-2005 08:52 PM
