CycleGear.comMotorcycle.com Classifieds!Springfield ArmoryBikeBanditAdvanstarMotorcycleShowsAnnitori DistributingbritishcustomsTrident-Exhausts.comSportbikeTrackGearMotorcycle.com
Tiger Chat For owners and riders of Hinckley Tigers: 885, 885i, 955i and 1050i
Old 05-10-2005   #1 (permalink)
Just put on a new rear and now I am wondering if the left spacer(looking from rear) is like a pipe nipple or if it has a larger flat surface like the one on the rght side of the wheel.I know,I have to breakdown and get a manual one of these days.
The reason I ask is now I rotate the wheel and I hear a sound like rubber rubbing.Chainguard is not rubbing,but thought maybe the spacer was rubbing on the rubber part of the seal/bearing.
Tia.
Gearloose is offline   Reply With Quote
Old 05-11-2005   #2 (permalink)
Favorite Bike: '06 Scrambler
Other Motorcycle: '07 F650 GS
Tia-
Flange is fitted with wide end up against swing arm on right side.
So if you think of it is a top hat, the brim is toward the outside of the bike and the top is toward the wheel.
Hope that helps.
Fred
No such thing as cold weather, just inappropriate clothing.
pigpen955 is offline   Reply With Quote
Old 05-11-2005   #3 (permalink)
Fred right side is ok,flange to s/arm it is the left side that I think is a reg.spacer with no flange,but I can't remember when I mounted the new rubber.
Old 05-11-2005   #4 (permalink)
Sorry about that. The left side is just a donut like spacer with no flange.
Are sure the noise you are hearing is not just the chain? Another possibility is that it is the rotor rubbing on the brake pads which had to be separated a little when you removed teh tire. Try just applying the rear brake once or twice. Finally, check to make sure the rear wheel is aligned properly.
Hope that helps,
Fred
Old 05-25-2005   #5 (permalink)
nova_wagon
I have a similar problem. I noticed yesterday that my sprocket bolts were rubbing against the swing arm. Carved a little grove in it ....eek. I'm not sure how it happened. I think the right side chain tightener slipped and caused the wheel to lean a little left. After realigning the wheel, the bolts clear the swing arm, but the gap is still reeeeal close.
I have to get off my arse and pull the rear wheel. Perhaps I lost a spacer when I had my tire replaced a few thousand miles ago. Now I know what to look for. Thanks guys.
Old 05-25-2005   #6 (permalink)
I used to have a squeek like that, traced it to the rear wheel spindle. One or two drops of oil cured it.
davie.
I,ve got a mountain of dreams to climb.
Do unto others as they are doing unto you.
tango is offline   Reply With Quote
Front Wheel Spacer Measurement Chumpmaster2k1 Tiger Workshop 10 10-02-2007 07:39 AM
Quick Wheel Spacer Question Goldendog Twins Technical Talk 23 08-19-2007 06:36 PM
17"rear wheel tridentman T3 Sport / Touring Forum 7 04-09-2007 04:14 PM
Rear wheel banging around - Watch that rear axle nut! n578md Twins Technical Talk 6 09-17-2006 02:49 PM
Rear Wheel DMc Sprint Forum 1 05-17-2005 06:20 PM
