Mod. Hazard flasher. - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger 800 - 800XC Mods & Workshop Workshop and technical talk for the 800 - 800XC Tourer - Adventurer Tigers
post #11 of 56 (permalink) Old 01-31-2013, 09:01 AM
Main Motorcycle: tiger 1050
Hi doctaton.
Must admit I thought your thread would have raised more comment.
when I first read it I was well impressed. I read it again after my first post and fully realised just how much time and effort you put into this project. The quality of your photography is stunning.
when it warms up here I plan to check under my tank. That is the location of the alarm connector on the 1050. From memory they are the same and I can do this great mod on my bike.
Thanks again JJ
johnjo is offline
post #12 of 56 (permalink) Old 02-03-2013, 02:48 PM Thread Starter
Main Motorcycle: Triumph SM 07'carbed
doctaton's Avatar
Originally Posted by johnjo View Post
Hi doctaton.
Thanks again JJ
Thanks for your words, John!
doctaton is offline
post #13 of 56 (permalink) Old 02-09-2013, 01:56 AM
Main Motorcycle: Tiger 800XC
Hi Doctation,
I am an infrequent visitor, but look for really useful stuff like this - so thanks for your trouble.
I have been in need of hazard lights on 2 occasions and figured there must be away to achieve this. Once repairing a flat on the side of a major highway and another when I was marking a fallen free across a road waiting for the State Emergency Services.
I'm going with method #2 right after this post.
Bad Juju is offline
post #14 of 56 (permalink) Old 02-10-2013, 04:12 AM Thread Starter
doctaton's Avatar
Re: Mod. Hazard flasher.
Originally Posted by Bad Juju View Post
Hi Doctation,
Thanks and good luck!
Anything you need, just ask!
Regards!
Aaah, btw, I'm not "Doctation"
Cheers!
Sent from my A510 using Motorcycle.com Free App
doctaton is offline
post #15 of 56 (permalink) Old 02-10-2013, 03:01 PM
Main Motorcycle: 2012 tiger 800
Syphoon's Avatar
Other Motorcycle: R90/6, R100/7,
Extra Motorcycle: 82Yam Seca 650
Hello Doc,
I tried to simply run a jumper wire from terminals 7 and 8, for testing purposes, to insure that I had the correct terminals. Which should work, I am only eliminating the switch. In short, I get nothing. Any ideas?
Syphoon is offline
post #16 of 56 (permalink) Old 02-11-2013, 06:21 AM Thread Starter
doctaton's Avatar
Originally Posted by Syphoon View Post
Hello Doc,
Hi Syphoon!
What do you mean?
Did you hit the turning lights switch after making the jumper?
I believe you've connected terminals 7 & 8, and when you hit the turning lights switch, nothing happens, just regular turning lights. Is it so?
If so, it's more than likely that the jumper isn't contacting one or both terminals.
Redo the jumper. I'd advise you to unplug the alarm connector, and do the jumper connection directly to the female pins, making sure they properly connect. Once you do that, you'll realise that when you hit the turning light switch, 4 turning lights will flash.
Please leave feedback!
Regards!
doctaton is offline
post #17 of 56 (permalink) Old 02-12-2013, 08:06 PM
Syphoon's Avatar
Originally Posted by doctaton View Post
Hi Syphoon!
What do you mean?
Regards!
I'm pretty sure I tried turning on the turn switch, but I might have had a brain fart. I will try again and report back.
Thanks again
Ed
Syphoon is offline
post #18 of 56 (permalink) Old 02-14-2013, 07:10 PM
Syphoon's Avatar
Thanks again
Ed
Update: I'm not sure where I went wrong the first time, but tried again today and it worked! Now I just need to do a permanent install.
I noticed the switch you used looked almost factory. What brand is it?
Thanks again.
Syphoon is offline
post #19 of 56 (permalink) Old 02-14-2013, 09:48 PM
Syphoon's Avatar
Thanks again.
One more update.
I was thinking that you would have to have the key on to use the flashers, but I found that if you turn the key to the parking light position, they will stay on! Excellente!
Syphoon is offline
post #20 of 56 (permalink) Old 02-23-2013, 04:44 AM Thread Starter
doctaton's Avatar
Thanks again.
It's chinese brand, lol!
Here is the link
One more update.
Yes, they do work in P position and that is absolutely great!
Thanks for your report!
doctaton is offline
Why no four way hazard flashers on the r3 MULESKINNER1 The Rocket Science Forum 7 08-02-2011 11:02 PM
Hazard lights? KitNYC Sprint Forum 11 12-18-2007 11:54 PM
a new road hazard iceman Biker Hang-Out 10 10-22-2007 01:55 PM
New road hazard Shaunlee Biker Hang-Out 18 05-08-2007 02:15 AM
