Hornzz - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Tiger 800 - 800XC Mods & Workshop Workshop and technical talk for the 800 - 800XC Tourer - Adventurer Tigers
Old 10-29-2012, 12:46 AM   #1 (permalink)
Main Motorcycle: 2012 tiger 800
Syphoon's Avatar
Other Motorcycle: R90/6, R100/7,
Extra Motorcycle: 82Yam Seca 650
Hornzz
I think everyone will agree how pathetic the stock horn is. They can't even wake a sleeping baby. I'd like to upgrade to Freeway Blasters or the like, but space seems to be very limited. Has anyone been able to do an install that isn't too unsightly. I know you can never make them invisible, but the cleaner the better.
Syphoon is offline   Reply With Quote
Old 10-29-2012, 10:01 PM   #2 (permalink)
Yal
Main Motorcycle: Triumph Tiger 800
check out this thread:
http://www.triumphrat.net/tiger-800-...eir-800-a.html
Yal is offline   Reply With Quote
Old 10-30-2012, 09:07 AM   #3 (permalink)
Loose Head Administrator
Supernova
Main Motorcycle: 2011 Tiger 800XC
propforward's Avatar
In that thread "The Haymaker" suggests under the tail piece. I think that's a great location - there is bags of room in there for a stebel. I might put one in there this winter myself, while farkling around. I have had to use the horn to prevent myself being run off the road a couple of times - and one time for sure a stebel would have been VERY advantageous.
"A long distance motorcycle trip, outside of your comfort zone, will probably be a defining experience in your life. It's miles cheaper, easier and safer than the celebrities and tour operators want you to think it is. Do a big trip, come back and encourage someone else to do theirs. Remember the kindness shown to you by strangers, then pass kindness on in your world thereafter. Simple"
Austin Vince
Old 10-30-2012, 05:48 PM   #4 (permalink)
Main Motorcycle: 2012 Tiger 800 XC ABS
XYooper906's Avatar
Other Motorcycle: 1974 Kawasaki F11 (sold)
I'll post some pics in the other thread tomorrow of my installation of the Wolo horn.
UPDATE: I have posted a link to some pictures of how I installed the Wolo. Follow the link above.
XYooper906 is offline   Reply With Quote
Old 11-03-2012, 01:13 PM   #5 (permalink)
Main Motorcycle: 2012 Tiger 800X/C
TheHaymaker's Avatar
Other Motorcycle: 2000 XR650R
Extra Motorcycle: 2004 CRF250R
Was gonna say, Mr. Yooper had cleaned up the install a bit from mine.
As far as stock horns go, be thankful. The Tiger horn is FAR superior to the dime store gizmo that was on my Ninja.
Also be forewarned on the Stebel, it goes silent at 6F.
TheHaymaker is online now   Reply With Quote
Old 11-04-2012, 06:19 PM   #6 (permalink)
Main Motorcycle: Tiger 800
Other Motorcycle: was fjr1300
I installed a pair of PIAA Slimline Horns. Vastly superior to stock. I plugged a relay into the leads for the stock horn and mounted it to the bolt on the headlight mount. I then mounted one horn in the stock location and the second is mounted lower on the crossmember of the Triumph engine guards. I picked up power from my auxillary fuse panel I that I had previously mounted under the seat. Pretty clean setup. Took about 2 beers to install and is nice and loud!!!
Total cost was about $60.00.
I always install a fuse panel (direct to the battery) on the last couple of my bikes.
Means I never have to splice into the factory harness and if I were every to have a problem with any accessory I just pull the main in-line fuse (be sure to install one) and it's back to the factory setup.
I use a Blue Sea unit from a marine supply but there are lots of choices out there.
TILAM is offline   Reply With Quote
Old 11-06-2012, 10:40 PM   #7 (permalink)
Syphoon's Avatar
Thanks for all the info guys. XYoop you did a great job getting all those close up shots, excellent detail. I wonder how much lag time you're getting with the distance between horn and compressor being a bit long?
One snag for me, I have a Roadie, so I'm missing the beak. If I decide to go that route, I guess that gives me a good excuse to buy the beak this winter.
Tilam, you say you mounted one of your horns on the crash bars, do have any pix of that? I've used twin Stebels and Fiamms on other bikes in the past, with good results. So I think that's more along the lines I had in mind.
Old 11-06-2012, 11:31 PM   #8 (permalink)
XYooper906's Avatar
Actually, I thought that there would be more lag than there is. I kept the stock horn hooked up for that reason, to add a bit more sonic assault, and in case the air horn ever quit. I find it quite difficult to just quickly bump the horn to give a friendly "meep" in traffic without the air horn kicking in. (1/8 of a second, maybe?)
It definitely makes a difference. I had a lady start to merge right in front of me the other day, and the Bad Boy announced his presence. She quickly changed her mind and gave a sheepish "sorry" gesture as I passed.....
Old 11-08-2012, 10:27 PM   #9 (permalink)
Syphoon's Avatar
I had a similar moment recently. On the Pa Turnpike, with a truck to my right, a woman in the left lane decided she wanted over. I gave a nice long blast, she hesitated a second, then proceeded to continue into my lane. If I hadn't sized her up in time, she would have put me under the truck's tandems. That's when I started looking at horn options.
