Mine came with the baffle out and I put it back in...there is a small screw inside at about the two o'clock position....mine was T30 screw head....take out the screw and put a broom handle down into the baffle and work it to loosen it....it's in there pretty good....That should break it free where you can pull it out....I had to tap mine carefully with a hammer to get the last little bit of the screw hole to line up when putting it back in.....It seemed a little loud with the baffle out to me
