| Tiger 800 - 800XC Mods & Workshop Workshop and technical talk for the 800 - 800XC Tourer - Adventurer Tigers |
07-31-2012, 09:05 AM
Loose Head Administrator
Site Supporter Supernova Main Motorcycle: 2011 Tiger 800XC
Posts: 25,703 Other Motorcycle: 2007 Bonneville Big Carbs Extra Motorcycle: G12DL, ZX1100, KLR650
Chain and Sprockets
Has anyone replaced their chain and sprockets yet?
Mine is coming up, not quite yet, but soonish, so I'm looking around at alternatives. So far, I'm leaning with just going with the OEM Triumph kit. It's 211 bucks from bike bandit, so my dealer will likely be similar in price.
Usually I can get better (higher strength rating - and gold coloured oooooooh!) chains via amazon.com for a lot cheaper, but it's not working out that way this time.
Has anyone come up with any aftermarket alternatives?
I have 20,000 miles on this chain, and it's still holding up well. No real tight spots or anything, and it's not stretched to its service limit yet, but it's starting to get there, so I want to get parts in and ready.
24K mile service won't be far off, so I need to get air filter and cam cover seals etc in anyway.
"A long distance motorcycle trip, outside of your comfort zone, will probably be a defining experience in your life. It's miles cheaper, easier and safer than the celebrities and tour operators want you to think it is. Do a big trip, come back and encourage someone else to do theirs. Remember the kindness shown to you by strangers, then pass kindness on in your world thereafter. Simple"
Austin Vince
08-01-2012, 04:58 PM
Site Supporter Formula Extreme Main Motorcycle: 2012 White Tiger 800XC
Are you thinking of changing up the gearing/tooth count while you're at it?
08-01-2012, 05:46 PM
Actually no. I am happy with how the bike runs, so I was just going to leave it as is.
Austin Vince
08-02-2012, 09:24 AM
Supersport 400 Main Motorcycle: Tiger
Not sure what year you have. My question would be if you go with after market parts before the two year warranty is up would that void any support from triumph?
Sent from my AT100 using Motorcycle.com Free App
08-02-2012, 11:20 AM
I hadn't thought about that aspect to be honest. I don't see why it would.
I think the warranty is actually 2 years / 24K miles right? In which case, since I think I will do this at the 24K mark, it doesn't matter much. Mine is a 2011XC. One of the first ones in Mn.
However, it looks like the OEM kit is a pretty good value based on the research I have done, I have ordered it.
Austin Vince
08-07-2012, 07:07 AM
SuperSport Main Motorcycle: 800 Roady
No, absolutly not why would it? That would be like voiding the warrantee for installing diferent brand of tire.
If the new chain or sprocket failed (not likely) obviously that's not covered.
08-07-2012, 08:12 AM
I've ordered a chain and sprocket kit from my dealer. 211 bucks, same as Bike Bandit.
I haven't been able to beat the price significantly with known good quality aftermarket brands. This is mainly because the chain is quite long (124 links) and most chains seem to be available up to 120 links, and then jump to 150 - which is pricey. Then the cost of the sprockets......anyway, it was clear that the value is reasonable so this time I'm just going OEM. Easy peasy.
With a bit more searching I bet I could do better, but good enough for now.
Austin Vince
