Tank protectors - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com
Tiger 800 - 800XC Mods & Workshop Workshop and technical talk for the 800 - 800XC Tourer - Adventurer Tigers
Old 07-08-2012, 03:45 PM   #1 (permalink)
Main Motorcycle: 800XC
Tank protectors
Any opinions on tank protector stickers? Good /bad idea? Any suggestions on brands? Will the adhesive permanently damage paint? Thanks
REXP800XC is offline   Reply With Quote
Old 07-10-2012, 09:30 AM   #2 (permalink)
Main Motorcycle: BMW K1600 GTL
iride4u's Avatar
I have the rubber pad from Triumph. You should be able to take it off with a hair dryer but why try.If you need more coverage then try the 3M film. I have that on my
BMW K1600 GTL it will come off again with a hair dryer.
iride4u is offline   Reply With Quote
Old 07-10-2012, 11:04 PM   #3 (permalink)
Main Motorcycle: 2012 Tiger 800 XC ABS
XYooper906's Avatar
Other Motorcycle: 1974 Kawasaki F11 (sold)
I was going to buy the paint protection kit from Triumph, but I remembered that a friend of mine did automotive clear bras as a side business. He was able to do the back of my tank, the entire front beak, and the headlight from scrap pieces he had on hand. He custom-made the patterns for each respective areas mentioned above. Using one piece per area took a bit of work to stretch into place because of all the compound curve/angles, but he did good job with it. I believe he uses the XPEL brand of film. It looks good!
The clear films are not supposed to block UV, so that the painted areas that are covered will not fade at a different rate than the uncovered ones, in case you decide to remove it later. As mentioned, a hair dryer will aid in the removal. The adhesive won't damage the paint.
XYooper906 is online now   Reply With Quote
Old 08-25-2012, 11:17 PM   #4 (permalink)
Main Motorcycle: 2011 Sprint GT (Silver)
Other Motorcycle: 012 Harley Ultra Ltd
Extra Motorcycle: 2012 Hayabusa
I cant bring myself to put clear film on the Tiger, its supposed to look rugged. I did put the Triumph pad on as it gives it character. I figure when the paintr gets messed up enough I will paint the bike with BBQ Grill flat black paint out of a $5 rattle can.
masterblaster1 is offline   Reply With Quote
Tank protectors mr hyde Street Triple Forum 80 03-31-2013 05:30 AM
Tank protectors mat Speed Triple Forum 0 02-21-2011 08:38 PM
Tank Protectors Mark99 Speed Triple Forum 4 09-03-2005 11:53 PM
Tank Slapper tank protectors blipco Triumph SuperSports 14 02-18-2005 01:38 PM
Tank Slapper tank protectors blipco Maintenance & Workshop Talk 2 12-31-2004 11:20 PM
