Captain Cheapo's mods - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Tiger 800 - 800XC Mods & Workshop Workshop and technical talk for the 800 - 800XC Tourer - Adventurer Tigers
Old 03-13-2012, 07:09 AM   #1 (permalink)
Main Motorcycle: Tiger 800XC
here's some cheapo mods I did on my XC. If you are worried about keeping your bike pretty you may want to look away..
First is a Captain Cheapo Cruise Control system. Using thin bungee cord wrap and tie to appropriate tightness around hand guard. Add doubled over two inch (5cm) Soft Velcro for Operation Handle.
How to Use: Using the Operation Handle - wedge bungee into gap between throttle and starter switch. Turn to appropriate speed. Enjoy wrist relief. To disengage - Using the Operation Handle - Remove bungee from gap and place in crevasse beside starter button. Enjoy normal throttle function.
raygunn is offline   Reply With Quote
Old 03-13-2012, 07:19 AM   #2 (permalink)
Captain Cheapo Mudflap
Using old car mats or other sources or free rubber at hand, cut out appropriate size mudflap. On mudflap use 2" Industrial Strength Self Adhesive Soft Side Velcro on top of flap. Remember to heat up the glue with an open flame of your choice to ensure good stickage.
Now on the bottom on the battery compartment exterior in the wheel weld place the Hard Side Velcro (don't forget to torch the velcro very briefly) Now attach the mudflap by marrying the velcros together.
Refrain from blasting this too hard with pressure washer.
Will it last? Time will tell.
Old 03-13-2012, 07:32 AM   #3 (permalink)
Captain Cheapo Tankbag
This is for other KLR owners who have seen the light.
Use your old KLR specific tankbag, Gently remove(800) side panels Remove Panel on tank near keyhole. Remove top of tank panel bolts and loosen the ones near the headlight assembly. Cut 1 inch line in tankbag where it would impede on replacing the keyhole panel. Using expletives - gently manouver tankbag into place and poke holes in appropriate place to facilitate getting top panels back on. Now pull the rear tankbag tabs down to the frame and wedge in using the 800 panels. As you can see, this is not a quick release system but you never have to worry about someone stealing your tankbag. It's a bit of a bitch but can be done and a cheap solution while you mull over which tankbag to buy.
Old 03-13-2012, 07:19 PM   #4 (permalink)
Main Motorcycle: Tiger Explorer
KevB's Avatar
Other Motorcycle: Ducati Hypermotard 1100
Originally Posted by raygunn View Post
...Captain Cheapo Cruise Control system...
Oh Captain Cheapo, you are my hero! Your cruise control system is so pathetically cheap and simple it's brilliant. No bolts, no nuts, no screws and no messing around taking things to bits or aligning stuff.
I love it.
Triumph Tiger Explorer
Ducati Hypermotard 1100 EVO
KevB is offline   Reply With Quote
Old 03-14-2012, 10:19 PM   #5 (permalink)
I like the cruise control. Might try that myself.
RichardU is offline   Reply With Quote
Old 03-14-2012, 11:07 PM   #6 (permalink)
Main Motorcycle: 2012 Storm
RBinTEX's Avatar
Other Motorcycle: 2010 Honda Phantom
Wow, hard to find so many people in one place with a death wish! I'm scared!
I sure hope that I'm on the joke page!
Even if it is a joke I hope no one does this and gets hurt doing it!
I didn't get to be 70 by doing or promoting something like this!
Ronnie ò¿ó¬
Texas Rattlesnake
RBinTEX is offline   Reply With Quote
Old 03-15-2012, 12:27 AM   #7 (permalink)
No Joke
Lighten up. you can still easily turn the throttle. it just takes much of the tension off.
Old 03-16-2012, 12:25 AM   #8 (permalink)
RBinTEX's Avatar
If you don't/cant see the inherit dangerous problem with it, I'm through talking about it!
I would just hate for someone to take your advise and get hurt, or worse, following your advise!
Some people just have to poke at the hornets nest with a short stick because they see nothing wrong with it!
Ronnie ò¿ó¬
Texas Rattlesnake
Old 03-16-2012, 06:17 PM   #9 (permalink)
I am not sure how it is any more or less an issue than any other throttle resistance mechanism. If you have a problem with them in general that is fine, but I see little basis to come on so hard regarding this particular implementation.
turboICE is offline   Reply With Quote
Old 03-17-2012, 08:19 AM   #10 (permalink)
RBinTEX's Avatar
Question
If you had a friend that was doing something that you knew was really wrong and had the potential to harm him, wouldn't you try to help him by warning him of the impending dangers?
Kind of like pulling him back up on the curb if a bus is going to hit him!
If I was about to step on a rattlesnake I feel that you would try to warn me about it instead of trying to get someone else to think that it was a good idea to step on the snake!
I'm trying to warn you as a friend, if I didn't care about your safety enough for me to warn you about a very dangerous situation that has the potential for harm, I would have just moved on and forgot about you and your Rube Goldberg apparatus.
Comparing dangling strings and Velcro to a manufactured throttle lock is .....well you know!
Now that I know you don't care about your personal safety enough to take the wisdom of my 70 years of experience and seeing little things like yours become life changers for people I will just move on!
If you don't want my caring advise maybe someone else that thought your idea had merit will give it a little more thought than you did and let good sense prevail!
Take care!
Ronnie ò¿ó¬
Texas Rattlesnake
captain don pz1 Twins Talk 5 01-24-2010 02:11 PM
Met a fellow captain TallTxGuy The Rocket Science Forum 4 12-18-2006 03:26 PM
El Cheapo's new sig!!! Cheapbastard Speed Triple Forum 42 06-06-2006 01:11 AM
Almost a Captain mdglaw The Rocket Science Forum 6 02-23-2006 05:52 AM
Was a Captain...... Aussiekeeper The Rocket Science Forum 22 02-22-2006 11:41 AM
