HIDs for new Tiger 800 - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger 800 - 800XC Mods & Workshop Workshop and technical talk for the 800 - 800XC Tourer - Adventurer Tigers
Old 08-08-2011, 11:56 AM   #1 (permalink)
Main Motorcycle: 2010 T100 Black / White
Has anyone put HIDs on the new Tiger 800 to replace the stock bulbs? Where did you install the ballasts? If you have done this successfully, can you please post pictures?
thanks!
fernandos1 is offline   Reply With Quote
Old 08-08-2011, 03:14 PM   #2 (permalink)
Main Motorcycle: Tiger 800 Venon Yellow
KildareMan's Avatar
thanks!
Not necessary. Twin H4 setup is brilliant. Replace the stock filaments if you feel the need - Osram Night Breaker plus was what I used. Compared to my Tiger 1050 with Hids the 800 is streets BETTER.
Venom Yellow
KildareMan is online now   Reply With Quote
Old 08-09-2011, 07:28 AM   #3 (permalink)
Good to know, thanks. Couldn't find the Osram bulbs so I ordered the PIAA Intense White ones. Is the process of changing the bulbs fairly simple to do for someone who is not very mechanically inclined?
Old 08-09-2011, 07:42 AM   #4 (permalink)
KildareMan's Avatar
Simple enough. The black rear covers twist off revealing the bulb & connector. Pull off connector, then open spring retainer and remove bulb. Reverse to fit new bulbs. DO NOT touch the glass of the bulbs as this can cause them to fail quite quickly due to the oils on your skin.
Venom Yellow
Old 08-09-2011, 11:54 AM   #5 (permalink)
That's easy enough!
I think the bulbs should be here today along with my Givi Case and new Helmet. It's going to be a busy and fun night!
Old 08-11-2011, 04:12 PM   #6 (permalink)
Put them on last night and they work great. White, bright light without the yellowing of the OEM.
Old 08-16-2011, 07:29 PM   #7 (permalink)
Main Motorcycle: Aprilia Falco SL1000R
HID's in a non-HID housing is never a good idea. Not a sharp enough cutoff and you end up loosing a lot of light to scatter. They may look bright if you look at them but that's because a lot of the light isn't hitting the road. I learned the hard way
barmato is offline   Reply With Quote
HIDs on 02 sprint oldschoolsdime92 Sprint Forum 7 12-17-2009 06:55 AM
HIDs makton3g Daytona Deliberations 9 09-24-2007 08:09 AM
HIDs on 07 S3 nyamwegi Speed Triple Forum 1 05-05-2007 08:04 AM
HIDs on an S4 FuryFour Triumph SuperSports 7 01-18-2006 08:01 PM
anyone put hids in their triples? Speed Triple Forum 3 12-31-2004 01:28 PM
