Charcoal Canister Removal (North American bikes) - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com
Tiger 800 - 800XC Mods & Workshop Workshop and technical talk for the 800 - 800XC Tourer - Adventurer Tigers
Old 08-05-2011, 05:19 PM   #1 (permalink)
Main Motorcycle: 1968 Triumph Trophy TR6R
Other Motorcycle: 2012 Tiger 800XC
Extra Motorcycle: 2003 Bonneville T100
I have a question for Mac. Since this is my first EFI bike, I do not know if removing the evap charcoal canister would adversely affect the ECU. Can you give me any guidance in this? Are there any special tricks to the removal?
Carl S
Old Soldier
CarlS is offline   Reply With Quote
Old 08-05-2011, 11:54 PM   #2 (permalink)
Main Motorcycle: SIII 1050 07'
mnhoulden's Avatar
No, there are no adverse effects to removing the CC. I just removed mine off my S3. Get 4 end plugs, reuse the clips from the hoses and Bob's uruncle! The one lead you have to unplug can just be tied up and left. No engine light.
I can't see this being too terribly different between yrs and range. The CC serves the exact same purpose.
Good luck!
Cheers,
Mark
www.azdirtyaces.com Motomarathon, CO. 2010 ASMA #309 IBA#34978~ SS1000~ 10.11.08 B2B Insanity~ BB1500~ 10.17.10
Alaska Blog- http://3umphak.wordpress.com/
mnhoulden is offline   Reply With Quote
Old 08-06-2011, 01:51 AM   #3 (permalink)
Super Bananarator
Main Motorcycle: Street Triple R
MacBandit's Avatar
Other Motorcycle: 97 Honda CR250R
Extra Motorcycle: 96 BMW K1100RS
No it does not hurt anything. In fact most Street Triples shipped without them until the new 2012 models. The Street Triples that came without are identical in every way as the ones that came with them except the didn't have the canister.
MacBandit is offline   Reply With Quote
Old 08-06-2011, 08:07 AM   #4 (permalink)
Thank you very much Mark and Mac. I appreciate the replies. That is my project for this morning. I will keep the canister - just in case I need to install it again.
Carl S
Old Soldier
Old 08-06-2011, 09:11 PM   #5 (permalink)
Main Motorcycle: 1960 Triumph Tiger T100A
adsinger's Avatar
Other Motorcycle: Laverda,Bultaco,BMW,MZ
Extra Motorcycle: Moto Guzzi,Yamaha,Honda
I'm considering doing this as well. I have a question. Is there a vacuum line involved that needs to be plugged? I know that's how the BMW's work. Anything else I need to know?
Thanks.
alan.
www.MotoEuro.org
adsinger is offline   Reply With Quote
Old 08-06-2011, 09:40 PM   #6 (permalink)
I haven't traced it all out yet; but I am sure there is a vacuum line. These systems are all basically the same.
Carl S
Old Soldier
Old 08-07-2011, 12:09 AM   #7 (permalink)
mnhoulden's Avatar
Thanks.
alan.
Yes there is but you don't need to plug it! It use to run from your tank to the canister. Now you need to run it to the ground, like your other lines. If it is the one I am thinking then it comes from the tank, yeah? When eliminating this line on my S3 I also got rid of the little back-flow canister that was attached to the line.
Cheers,
Mark
Old 08-07-2011, 12:48 PM   #8 (permalink)
Main Motorcycle: 2012 Tiger 800
Other Motorcycle: 99 Legend
Extra Motorcycle: 2002 Speed Triple
What is the benefit to removing the CC?
geebee is offline   Reply With Quote
Old 08-07-2011, 05:34 PM   #9 (permalink)
It is in the way of mounting some third part sump guards and center stands. One person reported that it sucked in water when fording and caused the bike to stall.
Carl S
Old Soldier
Old 08-07-2011, 08:43 PM   #10 (permalink)
Main Motorcycle: Tiger 800XC
I suspect you are going to need to keep the tank to canister hose open. Unless the gas cap is non sealing. If the gas cap is sealing, which I expect it is, you need to have some vent to keep pressure from building up in the tank when its hot and sitting in the sun and to keep vacuum from builing up in the tank when you are using up the volume of gas.
Also I have no idea if the Tiger's diagnostics are the same but some car diagnostics have a valve that determines when and where canister fumes are pulled from the canister (especially on turbo cars) and when the canister is removed eventually it will throw a check engine code. It is usually a very long diagnostic period like 500 miles before it shows up.
turboICE is offline   Reply With Quote
removing charcoal / emissions canister JonahP Street Triple Forum 3 06-26-2008 02:44 AM
Scrambler Charcoal Canister Q The Jerk Twins Talk 8 05-19-2008 09:14 AM
California Charcoal can removal Donkeypunch Twins Technical Talk 4 07-31-2007 11:06 PM
California Charcoal can removal? Donkeypunch Maintenance & Workshop Talk 1 07-31-2007 07:42 PM
CA charcoal evap system removal help? chadoll Triumph SuperSports 0 05-14-2004 03:10 AM
