Panel Removal - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger 1200 - Mods & Workshop Workshop and technical talk for the 1200 Tiger Explorer
Old 07-13-2012, 04:44 PM   #1 (permalink)
Main Motorcycle: Tiger Explorer
doughnut's Avatar
Other Motorcycle: '10 Street Triple R
Panel Removal
Has anyone removed the plastic panels along the gas tank? I have some wiring to do and am wondering how to remove them without breaking anything!
Thanks!
Fighting imbecility one person at a time
doughnut is offline   Reply With Quote
Old 07-19-2012, 03:18 AM   #2 (permalink)
Newbie
Main Motorcycle: 2012 Triumph Explorer
I did just out of curiosity one night. The come right off, just start removing bolts and covers, nothing tricky.
lightisright is offline   Reply With Quote
Old 07-27-2012, 02:36 PM   #3 (permalink)
Main Motorcycle: Tiger 1200
Other Motorcycle: bmw1150gs, klr650,
Extra Motorcycle: daughters Buell (pink):-)
The black piece (not painted) slides back and doesn't just pop off. after you get the bolts off.
safetybob is offline   Reply With Quote
Old 07-30-2012, 12:55 PM   #4 (permalink)
Main Motorcycle: waiting delivery off ...
Olympus's Avatar
Other Motorcycle: Husky 610
The ones at the back of the tank have one bolt on each side under the seat, the front of the panel has a plasic peg which pushes into a rubber grommet. Pull the front outward about 5mm & slide the panel rearward
All the others are simply on bolts ....dont forget there is one under the "Triumph" badge
If your looking to remove the tank, the biggest problem is the front cross over fuel pipe..
Some days your the pigeon and others the statue
Olympus is offline   Reply With Quote
Help! Crankcase panel removal hyperview Twins Technical Talk 17 11-01-2012 12:00 AM
Side Panel removal ?? chas1050 Speed Triple Forum 4 11-06-2011 06:19 AM
side panel removal chas1050 Speed Triple Forum 1 01-30-2010 10:34 PM
instrument panel removal keyanwelch Twins Technical Talk 10 03-06-2009 03:53 PM
Side panel Logo removal? Twins Talk 23 08-17-2005 07:44 AM
