K&N Oil Filter Leaked - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger 1050 - Mods & Workshop Workshop and technical talk for the 1050 Tiger
post #1 of 17 (permalink) Old 07-10-2015, 06:06 PM Thread Starter
Main Motorcycle: 2010 Tiger 1050
TommyTFC's Avatar
Other Motorcycle: BMW R1200GS
I installed one of those K&N filters with the nut spot welded on the bottom. After 4000 miles it started leaking around one of the spot welds. I was on a trip and 750 miles from home. At the time I could not believe it and thought the seal was leaking or the oil pan had cracked. After cleaning it up I started the bike and sure enough the oil flowed from around the welded on nut. I sent off a comment to K&N but as expected, nothing. Just thought I'd pass along my experience.
K&N Oil Filter Leaked-img_20150624_114414.jpg K&N Oil Filter Leaked-img_1936.jpg
TommyTFC is offline
post #2 of 17 (permalink) Old 07-10-2015, 10:07 PM
Main Motorcycle: '03 T-100 & '08Tiger1050
I have read of this happening before. I have never used one of their oil filters because the size of the nut, location, and method of attachment is a BAD idea that should never have been acted upon by K&N, IMHO.
Larry
RedBird is offline
post #3 of 17 (permalink) Old 07-11-2015, 10:52 AM
Main Motorcycle: 2013 Scrambler
vonfink13's Avatar
Other Motorcycle: 1985 Kawasaki 700 LTD
had one fail on my scrambler about a month ago.. got rid of it and went with the stock triumph filter... 500 miles later.. no problems...
vonfink13 is offline
post #4 of 17 (permalink) Old 07-11-2015, 11:06 AM
Main Motorcycle: Ducati Monster S4RS
Hypurone's Avatar
Other Motorcycle: 2010 Thruxton RS
and just to be the devils' advocate, I have used K&N filters on everything I own for at least 20 years without a single failure.... A couple of my vehicles were in the 80psi oil pressure range too!
As with anything mass produced there are bound to be a few incidents at some point... You should contact K&N and tell them what happened. I am sure they would be interested in learning what happened and may even send you a replacement/refund....
Chuck's Garages Thruxton
Camaro
Monster
'10 Thruxton RS 944cc - In the Faster Color
"You Were Really Flyin' When I Passed You Back There!"
Hypurone is offline
post #5 of 17 (permalink) Old 07-11-2015, 12:26 PM
"and just to be the devils' advocate…"
K&N might wish you had chosen a different way of saying your point.
Larry
RedBird is offline
post #6 of 17 (permalink) Old 07-11-2015, 12:40 PM
Hypurone's Avatar
Camaro
Monster
Hypurone is offline
post #7 of 17 (permalink) Old 07-11-2015, 12:51 PM Thread Starter
TommyTFC's Avatar
I wrote K&N on June 24th. I've heard nothing.
This was my first K&N oil filter. I agree that mass production can let a few get by. I'm not upset really. Surprised mostly. Can't say having no rear brake for 750 miles was comforting but I made it just fine. It was the 2 days of detailing and disassembly to get all the oil out that was the inconvenience.
TommyTFC is offline
post #8 of 17 (permalink) Old 07-11-2015, 03:53 PM
Main Motorcycle: 2014 Triumph Tiger 800 XC
blue-star's Avatar
Other Motorcycle: 2008 Yamaha Road Star
Extra Motorcycle: 2008 Kawasaki KLR 650
I have also never had a problem with the K&N filter. Used a bunch of them on several different bikes now. Hope there quality control isn't going down the toilet.
blue-star is online now
post #9 of 17 (permalink) Old 07-11-2015, 04:21 PM
Hypurone's Avatar
I hear ya man. That had to be just plain awful!! And I wouldn't blame you if you never used another one... I just wanted to throw it out there that by far and wide they have a great track record.
God I hope not... Seems like everything these days is going downhill!!
Camaro
Monster
Hypurone is offline
post #10 of 17 (permalink) Old 07-13-2015, 06:52 PM
Main Motorcycle: '11 tiger 1050
zrx4me's Avatar
I had an oil leak on my tiger and it always came from around the filter area.after my 2nd K&N I went back to the stock triumph and no more oil leak.
'11 tiger 1050 ABS
zrx4me is offline
Bosch 3300 Oil Filter No Longer Fits Our Bikes Caprock Air Cooled Twins Technical Talk 25 05-03-2016 09:13 PM
Fumoto quick oil drain valve (Long & Boring) Forchetto Air Cooled Twins Technical Talk 36 05-02-2015 09:49 PM
Oil leak around the filter chip1441 Air Cooled Twins Technical Talk 14 04-04-2015 10:53 PM
OIL filter stuck... Help! J-E Air Cooled Twins Technical Talk 30 03-28-2015 09:46 AM
multiple punch marks on crankshaft - this a problem? jonkster Classic, Vintage & Veteran 186 03-12-2015 08:00 PM
