Originally Posted by Lord Kelvin
I found that oil brands and types make a big difference in how well the transmission/clutch works. Mineral oils make for clunky shifting, Rotella T6 works all right for a short while, then shifting gets clunky again. Valvoline T4 synthetic, much the same as Rotella. Only oil I've used so far that works is the Factory specified Mobil 1 T4.
Hi, I am using Silkolene pro 4 plus 10w-50 fully syn oil at the moment,
The gear shifts are good for this type of bike,
Strange that I get this click sound with the bike moving along at low speeds when I press or release the clutch, without changing gear,
This only starts to happen when the bike temp is hot (6 Bars) in London Traffic,
I tried different drive chain settings from tight 35mm to around 45mm to check it was not chain slap, But no difference,
It's been the same since I bought the bike in early 2011,
Going to try a Motul chain grease soon, just to confirm its not the Dry lube grease I am currently using,
