Couple questions about forks and clutch - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger 1050 - Mods & Workshop Workshop and technical talk for the 1050 Tiger
Old 07-23-2012, 08:26 PM   #1 (permalink)
My bike is a demo bike, so I expected some wear on it.
However a couple of things have stumped me.
1) There isn't a lock nut on the clutch tensioner at the handle?
That thing is a coarse threaded bolt that is constantly backing out on me when I adjust the nut. Was the supposed to be a lock nut or was that not part of the design?
2) The stems of my fork tubes have two different designs.
For the record I'm referring to the cap that protrudes from the triple clamp.
The left tube has a silver cap that says "TEN S<->H" on it. I assumed the TEN stood for tension, but the other one is gold and says "Comp S<->H" on it.
Uhhmm, is it supposed to be like that? if so, why, if not, which one is factory original?
eigenvector is offline   Reply With Quote
Old 07-23-2012, 08:45 PM   #2 (permalink)
Main Motorcycle: 2010 tiger 1050
http://www.scribd.com/doc/22841269/T...95NG-NH-OHB-UK
Not sure how it works yet but the information is covered in the owners manual. The preceding link is for a 2010 1050.
lwmecham is offline   Reply With Quote
Old 07-23-2012, 08:54 PM   #3 (permalink)
Well at least I know the name of the fork tube cap - rebound/dampener adjuster.
The clutch was a wash - they indicated a lock nut but did not show it.
I'll poke around online some more.
Old 07-24-2012, 01:44 AM   #4 (permalink)
Tmod's Avatar
Yes they are supposed to be like that as one leg controls the compression and the other controls the rebound.
Tmod
The Best You've Ridden Is The Best You Know
Tmod is offline   Reply With Quote
Old 07-24-2012, 10:09 AM   #5 (permalink)
Hmm, interesting. I would have expected both fork tubes to have the same design.
Now I know.
Thanks for the replies.
Couple of questions crackerman Hinckley Classic Triples 12 05-25-2012 05:43 PM
replacing clutch and primary chain, couple of questions? razman Classic, Vintage & Veteran 3 07-31-2011 09:28 AM
couple of questions triple595 Triumph SuperSports 6 07-20-2010 07:53 AM
new guy with a couple questions kngkong Classic, Vintage & Veteran 8 05-07-2009 12:46 AM
Couple of ST questions L0giX Sprint Forum 3 05-04-2007 05:55 AM
