Sidestand safety switch failing - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 4 (permalink) Old 06-19-2017, 02:34 PM Thread Starter
Newbie
Main Motorcycle: 2012 Thunderbird Storm
Hello!
Has anyone had their sidestand safety switch fail? I have a 2012 Storm and I think mine has about had it. At first it was only an issue in really hot weather (no idea why) and now it is happening intermittently even when it is not hot. It does not recognize that the sidestand is up and will kill the engine when I shift into first. The plunger type actuator for the switch has been cleaned and lubed and is moving freely. When it happens, if someone reaches down and messes with the actuator, I can restart the bike and shift into first and not stall. Sometimes it takes more than one try. Wondering if I should replace the switch or just try to get someone to bypass it? Seems like an odd item to fail and I don't want to replace it if it is a common issue and might happen again.
Thanks in advance for any info you have.
Lisa
lnorton is offline
post #2 of 4 (permalink) Old 06-19-2017, 03:24 PM
Other Motorcycle: n/a
Mine was malfunctioning early on my 2012 bird. A little wd40 fixed it and I haven't had a issue since.
joey1970 is online now
post #3 of 4 (permalink) Old 06-19-2017, 03:35 PM
Main Motorcycle: 2010 Thunderbird SE
Stratofaster's Avatar
Other Motorcycle: eventually
I haven't seen many complaints about the switch on this forum. Mine malfunctioned once on a trip 4 years ago--I had ridden it through some pretty extreme rain and went through some pretty deep water. The switch did the opposite of yours; i.e., it allowed me to put the stand up with the motor running while in gear.
Once home and after a good bath, the switch returned to normal and has been fine ever since. It must have been dirty and wet.
If it were my bike I would fix it rather than by-pass.
Stratofaster is offline
post #4 of 4 (permalink) Old 06-20-2017, 05:37 PM
Main Motorcycle: 2010 Triumph T-Bird
Other Motorcycle: 1998 triumph T-Bird
Extra Motorcycle: 1981 honda xl500
guys,
Back in the day before the switches, the thrill of hitting a down kick stand when turning left will scare the holy hell out of you. So yes fix it.
good luck
Dan
danr620 is offline
Repairing or Repalcing Neutral Safety Switch Back2-2 Air Cooled Twins Technical Talk 2 04-07-2017 03:51 PM
Cheap ignition switch fix Ripper Air Cooled Twins Technical Talk 32 08-05-2016 10:54 PM
Ignition Switch Cable Failure pushr0d Sprint Forum 3 06-29-2015 09:20 AM
Have Immobilizer, dump ignition switch? 15Ace Air Cooled Twins Technical Talk 3 05-31-2015 08:44 AM
Kill switch wiring on T140V neal77bonnie Classic, Vintage & Veteran 13 03-30-2015 09:17 AM
