Overheat issue - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 10-30-2012, 01:03 PM   #1 (permalink)
Main Motorcycle: 2000 Thunderbird Sport
Cyclepath's Avatar
Other Motorcycle: 2010 R1200GS 30th aniv.
Extra Motorcycle: 2006 Triumph Scrambler
Overheat issue
Hi all,
I'm a regular participant in the triples section, but I have a question about a 1700 twin.
i have a 2010 Thunderbird with a factory installed 1700cc kit. 2000 miles.
The other day both the engine overheat light and the check engine light can on after about 10 miles of riding. We shut it off and flat bedded it home. Coolant level appears normal. Running it now at idle, the fan cycles on and off normally, and it doesn't overheat.
Has anyone else had a similar experience?
Cyclepath is offline   Reply With Quote
Old 10-30-2012, 01:40 PM   #2 (permalink)
Main Motorcycle: Triumph Thunderbird ABS
BigGuy82's Avatar
Originally Posted by Cyclepath View Post
Hi all,
It's a long distance guess, but I'm thinking it's a sensor issue since the level is normal and the fan is cycling. Also, when you restart it cold, does the light come on right away?
"The wire is life ... everything else is just waiting ..." - Karl Walenda
"My Triumph is living ... everything else is just boring ..." - BigGuy82
BigGuy82 is offline   Reply With Quote
Old 10-30-2012, 02:43 PM   #3 (permalink)
Main Motorcycle: 2011 Tbird
BMK9251's Avatar
Did you check your oil level?
BMK9251 is offline   Reply With Quote
Old 11-02-2012, 08:04 PM   #4 (permalink)
Main Motorcycle: TB1600 SE
Low Volts?
I had a very similar episode on the way home with my brand new 1600 bike. I figured it might be a confused computer so I unhooked the battery and check volts. I also picked up the tank and looked for loose hoses or connectors. Wiggled the fuses. Then I left it unconnected for 15 minutes and hooked it back up. Check Engine and Oil/heat light went out and it's never happened again. Hope it sorts out quickly.
capt_ted is offline   Reply With Quote
Old 11-03-2012, 10:41 AM   #5 (permalink)
Main Motorcycle: 11'tbird storm
steve59's Avatar
Other Motorcycle: twin cam lowrider 95ci
the bikes do run hot during break in but, this the first post i've read about overheating.
steve59 is offline   Reply With Quote
Old 11-04-2012, 07:36 AM   #6 (permalink)
Cyclepath's Avatar
Problem resolved. Bad coolant temp sensor. I was able to duplicate the issue a second time. One nice thing about Triumph is their diagnostic connector is the same OBDII connection that all cars use now, so a generic diagnostic tool was able to display the fault code.
Thanks for all the comments!
Old 11-04-2012, 11:50 AM   #7 (permalink)
You should get a cable for tuneECU. It will diagnose via fault codes too. You can do it w/o going to the dealer. Of course it'll do a lot more too including it's main function, loading or altering maps. Cable is about $10-20, tuneECU is free.
overheat light R0B Hinckley Classic Triples 13 08-16-2012 07:41 AM
Do Speedmasters Overheat? durdle Cruisers - America, Speedmaster 12 02-14-2012 10:30 AM
Did I really overheat this thing? TstorkBIRD Hinckley Classic Triples 7 10-27-2011 09:07 AM
will it overheat rcarpent Hinckley Classic Triples 8 05-05-2010 03:23 PM
Overheat light comes on with flashers Fozzy Hinckley Classic Triples 1 09-14-2004 04:45 PM
