Tbird Oil Change ***?? - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 10-29-2012, 02:09 PM   #21 (permalink)
Main Motorcycle: Triumph Thunderbird ABS
BigGuy82's Avatar
Originally Posted by BigGuy82 View Post
With the bike in a roughly upright position and the engine fully warmed, a filter change and oil dump should yield 4.4 quarts (this is the written factory spec). Something is wrong, but I don't have a clue what could be preventing the oil from draining properly unless the bike is not upright and/or the oil is not hot enough.
Regarding the dealer who told you that the bike only takes 3 quarts ... that is a person who clearly does not have a clue. Get a new service tech or do it yourself before this guy causes some real damage.
Steve59 - I just noticed something last night that will change the amount of oil you get when you drain the bike.
I always put the bike in a somewhat upright position by using a wood block under the kickstand (dangerous if your not paying attention to how much the bike is favoring the right, especially if you put any weight at all on that side like boosting yourself up off the floor.) I then drained the oil and then set the bike back down on the kick because it's easier to get the plug back in. However, I always left the pan under the bike. Last night, I pulled out the pan, then put it on the kickstand ... at which point approximately another 1/2 quart drained onto my garage floor. This of course makes total sense because the drain plug is on the left side.
I file this under "you learn something new every day" or as Forrest's mom said, "stupid is as stupid does".
"The wire is life ... everything else is just waiting ..." - Karl Walenda
"My Triumph is living ... everything else is just boring ..." - BigGuy82
BigGuy82 is offline   Reply With Quote
Old 11-03-2012, 10:51 AM   #22 (permalink)
Main Motorcycle: 11'tbird storm
steve59's Avatar
Other Motorcycle: twin cam lowrider 95ci
you know I rocked it back & forth a bit b4 pulling the plug but I rode it up a couple 2x6s to fit a pan under it so was leary of leaning it to much. I'd bet the shop leaves the bike on the jack too explaining their similar results. thanks for the heads up.
steve59 is offline   Reply With Quote
tbird sport/tbird header pipes - difference? deadman Hinckley Classic Triples 4 06-18-2012 08:55 AM
Seats interchangeable between Tbird & Tbird Sport? Creagz Hinckley Classic Triples 2 03-08-2011 01:03 PM
tbird sport carb rubbers for tbird & legend Spooner Hinckley Classic Triples 14 08-11-2005 01:45 AM
Wanna change those seat bolts? Tbird etc...? Tbird02 Maintenance & Workshop Talk 5 08-19-2004 09:09 PM
Tbird coolant change Slinky Maintenance & Workshop Talk 3 07-14-2002 03:56 PM
