Problem with my 2012 T-bird... any advice? - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 08-09-2012, 07:15 PM   #21 (permalink)
Main Motorcycle: 2012 Thunderbird
Other Motorcycle: n/a
I took a better look at it today and I think Daz is right. It looks to be routed funny. I was able to slip a plastic zip tie under the tank and secure it to the upper frame bar (not too tight of course). Hopefully that'll keep it in place.
Sent from my Motorcycle iPhone app
joey1970 is online now   Reply With Quote
Old 08-11-2012, 10:05 PM   #22 (permalink)
Main Motorcycle: 2011 Triumph Thunderbird
Scarecrow03's Avatar
Originally Posted by joey1970 View Post
I just broke 500 miles on my t-bird. I have not yet scheduled the 1st service because I'm still waiting for the accessories package that Triumph included with the bike. My dealer is gonna put them on during the first service.
Anyway.. this past weekend.. i was out for a short ride. I was about 3 blocks from my home when suddenly.. I heard a pop/clunk noise. It sounded like it came from the exhaust. Suddenly.. the bike stalled and the check engine light came on. I started it back up.. and it stalled again. It continued to stall. I had to keep the throttle heavy.. til I got it home.. to keep it from stalling again.
It was a Saturday.. but I called my dealer. He told me to check under the tank and look for two sensor tubes. After 5 minutes of trying to identify them.. I finally did. One of them had come off the nipple it was attached to. I reconnected it.. and it started back up. After riding a few blocks.. the check engine light went out. It seemed like things were fine again.
Anyway.. it could be my imagination.. but since this incident on Saturday.. my t-bird feels like it's lacking power. To me.. it seems to hesitate on acceleration. Also.. it doesn't seem to "sound" the same either. Tho I'm still running stock pipes (I'm waiting on a set of hog slayers). It's very subtle.. so I'm not quite sure if it's legit.. or if I'm imagining it. LOL.
Anyone have any ideas?
I'm hoping to get it in for the 1st service within the next week or two.. so I'm sure they'll check it out. But the dealer is just too far away to bring it in until the accessories show up. I don't wanna have to make two trips.
I had the same exact issue with my bike, I kept bringing it back, in all probably five times. The dealership contacted Triumph only to find that the recommended fix was to superglue the fuel hose into the tank. ***?! I was incredulous to hear this but am happy to report that I've not had an issue since then and that was about a year ago.
- John
Truisms in the Universe:
-Eagles may soar, but I've never seen a weasel get sucked into a jet engine.
-The early bird may get the worm, but the second mouse always gets the cheese.
-With enough force you can break your own finger up your...
Scarecrow03 is offline   Reply With Quote
Old 08-12-2012, 06:53 PM   #23 (permalink)
Newbie
Main Motorcycle: triumph t-bird
Other Motorcycle: 2001 trophy
same exact problem as joey1970
how is the 12min tune done, by the way mine is just over 500 mile,didn't even get to my first service
one trick pony is offline   Reply With Quote
Old 08-12-2012, 07:20 PM   #24 (permalink)
Newbie
Old 08-12-2012, 08:23 PM   #25 (permalink)
Main Motorcycle: Triumph Thunderbird
Turn it on without touching the throttle, let it idle until the fan comes on and wait at least 12 minutes.
As far as the first service goes, I just had it. They check the ECU for codes and my dealer said they change the tune. I don't know about that but they do hook up the ECU on line to check the bike out. I know they changed something because the idle is lower, about 750 where it was 1000 when I bought it.
Sent from my iPhone using MO Free
dougl is online now   Reply With Quote
Old 08-14-2012, 01:23 AM   #26 (permalink)
Main Motorcycle: Triumph Thunderbird ABS
BigGuy82's Avatar
So I'm enjoying the ride as usual. The T'Bird is humming along, looking and running great with no problems at all. I decide to have dinner, so I pull in for a burger - 30 minutes tops. I hop back on the 'Bird and cough, pop, wheeze, die. Try it again - same. Try it a third time and crack the throttle a little and shazam - it runs! Drive to the first light - dies. Restart, next light, ditto. Remembering what I read here about the MAP sensor tubes, I pull over but for the life of me, I can't find the stupid tiny tubes, not knowing that they are tucked in way to the front of the tank and that they are easy to find if you trace them from the throttle body. So, I drive it the twenty miles home, nursing the throttle at every light. Bike cools down, I look at the manual so I can find the tubes. I know this will shock some of you, but the tube was disconnected! Remember, it was running just fine until I parked the bike then re-started, making me wonder if perhaps there's a pressure issue pushing these damn hoses off. Anyway, I reconnected the tube and the bike ran fine, although the engine light stayed lit. I'm pretty sure the force tune will cure this, but I won't be able to do it until the morning when the engine is cold.
Here's the issue that I have with this. Obviously, this is a fairly common but easily fixed malady. So, why doesn't Triumph fix it? Really, the way that the tubes are affixed to the nipples is anything but reliable ... it's just a simple fit and the rubber nipple really isn't on there that tight. Super Glue - Triumph has got to be kidding! Regardless if this "cure" works or not, I'll be damned if I'll do some half-a**ed shabby repair on my bike just because Triumph wants to facilitate an easy cure for a problem that needs fixing. Come this weekend, the tanks coming off and I'll use small zip ties to fasten the nipple securely. Of course a better cure would be to take this little engineering FUBAR back to the drawing board and modify the fitting so as to make it truly reliable, but then again, the engineers might just decide to start super gluing each fitting at the factory ...
It's never the big things that get me going. It's always the details ...
"The wire is life ... everything else is just waiting ..." - Karl Walenda
"My Triumph is living ... everything else is just boring ..." - BigGuy82
BigGuy82 is offline   Reply With Quote
Old 08-15-2012, 07:50 PM   #27 (permalink)
Main Motorcycle: Storm
With the frequency this problem is occurring and the fact that this could wind up being a safety issue seems to me a recall may be in order. This machine suddenly quits in traffic we could be looking at a catastrophe.
Sent from my Motorcycle iPad app
Harry007x1 is offline   Reply With Quote
Old 08-17-2012, 05:20 AM   #28 (permalink)
Main Motorcycle: 2010 T-Bird SE
Daycruiser's Avatar
Anybody in the US file a compliant with the NHTSA about the hoses coming off?
Daycruiser is offline   Reply With Quote
Old 08-17-2012, 12:49 PM   #29 (permalink)
BigGuy82's Avatar
Daycruiser,
Not yet, but I have had frequent correspondence with Triumph and the dealer, indicating my concerns about this being a safety issue.. The dealer has dogged it relentlessly but Triumph not so much. They say they haven't seen much of it, but I can actually believe that (see my post "Solution To MAP Sensor Tubes That Fall Off).
I sent a second email to Peter Carleo today indicating my concerns. I'll give him a day or two to answer and then forward it to Triumphs CEO if he doesn't or isn't sympathetic to my point of view. If that flops, I'm submitting a complaint to NHTSA. Meanwhile, the dealer has been driving this through Triumph's service hierarchy for resolution.
If anyone else feels strongly about this, I suggest that you send an email to Peter and if that goes nowhere, to Triumph's CEO. I'll post contact info if anyone desires it. Also, this is my approach. If you want to go directly to NHTSA, I encourage you to do so. It's just my way to not involve our increasingly intrusive government and use them only as a last resort (sorry, couldn't resist the political shot!)
I'm hard pressed to believe that Triumph wants to alienate it's good customers, so I'm really hoping they act independently without government involvement.
Enjoy the ride!
Old 09-11-2012, 03:50 PM   #30 (permalink)
Main Motorcycle: 2010 Triumph Thunderbird
Originally Posted by Lantesh View Post
You can try the "12 minute tune." Search the site here of the details. It may help.
Not familiar with "12 minute tune."
My Bird did the same thing, limped back home, found one
tube off, replaced and now won't start. Yellow light still on.
WV RAT is offline   Reply With Quote
Anyone Heard About 2012 T-Bird LineUp Stacka Thunderbird Cruiser Chat 16 09-23-2012 11:31 AM
Low profile seat for 2012 T-bird jzRider Thunderbird Cruiser Chat 1 07-21-2012 07:32 AM
new member and a 2012 T-Bird Storm aspirant pedal2metal The Welcome Center 0 05-05-2012 03:12 PM
New to Triumphrat - T-bird Storm 2012 eazyrider The Welcome Center 0 01-13-2012 04:13 AM
Proud owner - 2012 T100 - looking for advice Rad43 Twins Talk 23 11-29-2011 01:45 PM
