Backyard Mechanics - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com
Old 01-11-2012, 06:16 PM   #1 (permalink)
Main Motorcycle: '11 Thunderbird Storm
mtnbykrtim's Avatar
Other Motorcycle: '98 Thunderbird Sport
Extra Motorcycle: '97 Harley FXD
Backyard Mechanics
The dealership in Pensacola, FL where I bought my 2011 Thunderbird Storm said I shouldn’t listen to the people that post in the Triumph forums. He called us all “a bunch of backyard mechanics.” Then he tells me I don’t know how to start a motorcycle. I’m 50 years old and have owned bikes my entire life. Granted fuel injected bikes are relatively new, I still believe I know how to start one. Mine has been hard to start whenever the temperature is cooler than approx. 60 degrees F. It starts without problem when the temperature is warmer. When starting cold I have to press the starter button as many as 5 times to get it to start and it smells flooded. If I touch the throttle even slightly while pressing the starter it fires right up the first or second time I try. The dealership said you have to press the button continuously until it starts no matter how long it takes. I asked about burning up the starter motor or draining the battery and he said the first won’t happen and if the battery fails I should bring it in for a replacement battery. The owner’s manual that came with the bike says to hold the button in no longer than 5 seconds and to wait 15 seconds before pressing it again to avoid burning up the starter.
What do you “backyard mechanics” think I should do?
mtnbykrtim is offline   Reply With Quote
Old 01-11-2012, 07:10 PM   #2 (permalink)
Main Motorcycle: 'Triumph Sprint Executive
Derswede's Avatar
Other Motorcycle: '95 Trident
He'd best not make that comment too often. Lots of "back-yard mechanics" have built some formidable vehicles (and some "fails" as well.) The best one I know has around 45 yrs experience and is an A/P).
Lots of his input on Pratt & Whitney engines....I'll trust his advice ANYTIME before some kid with a degree from the local community college.
Besides, most of those kids STARTED as backyard mechanics!!!
Derswede
Common sense is dead. The wake is tomorrow.
Derswede is offline   Reply With Quote
Old 01-11-2012, 07:46 PM   #3 (permalink)
Main Motorcycle: 2010 T-Bird SE
Daycruiser's Avatar
And here all this time I thought I was a Shade Tree Mechanic. What if you don't have a backyard? I do but I don't work on my bikes in it, I have a nice shop and a tree for that. Quickly take your bike to another dealer and let them know what his name was so they won't hire him when the dealer he works for now fires him for being stupid. Your bike isn't right, and the manual is correct about the starter.
Daycruiser is offline   Reply With Quote
Old 01-11-2012, 11:39 PM   #4 (permalink)
Main Motorcycle: 2010 Triumph T-Bird SE
Other Motorcycle: Kawasaki Vulcan 900 LT
Extra Motorcycle: None
I had the same problem with the cold start, my dealer did the TOR's download and it solved the problem. Run, don't walk to another dealer who doesn't have their head up their...
Mojo T-Bird is offline   Reply With Quote
Old 01-12-2012, 09:03 AM   #5 (permalink)
Main Motorcycle: 2011 Tbird
BMK9251's Avatar
First try the 12 minute adaption tune. If that doesn't work get the TORS download. BTW, I always work on my vehicles in the garage.
BMK9251 is offline   Reply With Quote
Old 01-12-2012, 10:17 AM   #6 (permalink)
Main Motorcycle: Thunderbird
Had exact same problem with mine. Told my service writer when I took it in for it's first service. Dealer tech said something about the TPS "closed" values being off. New download/reset TPS values-been perfect ever since.
Tallboy67 is offline   Reply With Quote
Old 01-12-2012, 04:12 PM   #7 (permalink)
mtnbykrtim's Avatar
I did the 12 minute adaption tune without any noticeable improvement. So I'm faced with a conundrum. The dealership is 2 to 2.5 hours away and the only dealership in NWF. The guy on the phone that tried so hard to insult me and everyone else that uses this forum picked up when I was put through to service. He used the same name as the owner and he sounded like the owner. I’d be happy to take my business somewhere else but there really isn’t anywhere else to take it. Either I go there or I do what I can myself. Can I download the TOR’s myself? If not, how do I get the dealership to do it when they have the attitude this guy has?
I've always considered myself a shadetree mechanic, too. Thanks for all the help.
Old 01-12-2012, 04:48 PM   #8 (permalink)
Main Motorcycle: 2010 Bonneville SE Black
echoraven's Avatar
Other Motorcycle: 2011 Rocket III Touring
This may sound kinda stupid, but when I start my bike I let the tach sweep forward and then backward completely (I guess while the ignition/fuel injection gets their marbles in place) and once it all goes silent I prod the starter button. When the weather is colder I pull on the fast idle one notch (where the choke would be on a carbed model) and that has worked for me... also keeping it on a battery tender helps!
...exposing Forchetto's real identity since 2011...
echoraven is offline   Reply With Quote
Old 01-12-2012, 05:35 PM   #9 (permalink)
Main Motorcycle: 2010 Thunderbird
navarre's Avatar
Sorry to hear you had such a bad experience with the dealership in Pensacola, I can assure you that your experience is the exception and not the rule. I’ve been dealing with that dealership for quite awhile now and everyone there has been extremely friendly and professional. They are a family run dealership who really go out of there way to support not just their customers but the community as well.
You can try Tallahassee; I think they have a dealership there. You can also go to Daytona Beach, I know the have one.
Anyway, I hope you get your bike issue worked out.
Hard times do not define a man but they will show you what he is made of.
navarre is offline   Reply With Quote
Old 01-12-2012, 05:45 PM   #10 (permalink)
Draeger's Avatar
Other Motorcycle: Anything on two wheels.
Fast idle notch? I'm guessing you are talking about a bike other than a Tbird, or does my Tbird have one of those?
If there is lead in the air there's still hope.
Draeger is online now   Reply With Quote
Hello to all you DIY mechanics captricky The Welcome Center 1 11-03-2011 01:56 AM
New Triumph Dealership in my backyard - Akron Ohio area ohiorider Twins Talk 6 01-05-2011 10:33 PM
To all mechanics out there raygun77 Speed Triple Forum 2 05-08-2007 07:04 AM
Backyard Tent/Canopy Bike Covers? Thunder_Forever Twins Talk 3 09-15-2006 10:07 AM
Mr. Bloors had Better Pay Attention to His Own Backyard 1fastcat Sprint Forum 37 06-14-2004 02:50 PM
