Power Accessory Outlet Done Easy - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 11-11-2009, 01:21 PM   #1 (permalink)
Favourite Bike: 2010 KTM Adventure 990 R
Rayzor61's Avatar
Other Motorcycle: 05 Speed triple (4th one)
Extra Motorcycle: Working on it!
It costs about $20.00 to install the accessory power outlet to the TBird. I wanted it to charge my cell phone and GPS via a cigarette type outlet. It had to be close to the dash to keep it clean. I also have a pouch type handlebar mounted storage bag to keep my devices in while chargeing and/or operating.
The Bell All Weather outlet mounts nicely to the top triple tree with zip tyes. It is available at Pep Boys and other auto stores for $12.95. Since I have the headlight cowling, it's very well hidden but fully accessable. There are many places to tie it to if you don't want it there (no cowling).
I bought a 10 Ft. length of the Battery Tender extension cord with the SAE 2 prong connectors. I removed one end of the extension to splice (with solder) to the outlet. I use some old plastic wire-cover sleeves to cover the connection and the ugly red wire on the outlet. The other end of the extension (power side) is routed under the tank and makes its was to the left side cover where I already have a battery tender lead. Just plug it in. When you want a trickle charge; disconnect and use the charger as normal.
Buy as many bikes as you can before you die, and try to live!
Rayzor61 is offline   Reply With Quote
Old 11-11-2009, 01:45 PM   #2 (permalink)
Good find! I was just thinking about one for my GPS. Thanks!
2010 Black ABS Thunderbird
1998 Honda Valkyrie Custom
"ata" = allergic to asphalt
ataDude is offline   Reply With Quote
Old 11-12-2009, 09:12 AM   #3 (permalink)
Favourite Bike: 2010 Triumph Thunderbird
engage's Avatar
This unit from powerlet wires directly to the battery and will power your GPS and cell phone (assuming your cell phone used a mini USB).
http://www.powerletproducts.com/prod...ry-harness/258
I have this on my bike.
engage is offline   Reply With Quote
Old 11-12-2009, 12:49 PM   #4 (permalink)
Thanks for the heads-up!
accessory outlet luckyrabbit7 Twins Technical Talk 3 06-06-2008 02:33 AM
accessory outlet luckyrabbit7 Maintenance & Workshop Talk 0 06-05-2008 10:37 PM
Accessory Power Outlet boreilly Sprint Forum 4 12-26-2007 07:05 PM
accessory outlet hodgy Daytona Deliberations 2 12-05-2007 01:23 PM
Adding accessory power outlet on 2004 Sprint RS? Blissed Sprint Forum 9 10-07-2006 02:50 AM
