Rite, sorry all for the cryptic last few hours i have been out and posting from my mobile so could not give the full story
as i stated today i purchased 2 meters of exhaust pipe, i finished work a bit early so set out to begin the task, for the last 24 hours i have been trying to think of ways to bend the pipe my self however this is not something i can do with the equipment i have so i settled with cutting the pipe with two angles and welding them together, at first i was not really happy with method as i would not have a clean bend for the gasses to flow around but one i mocked up the first pipe i realises it was less of an angle than i first thought so it wont be a problem.
the first mockup.
as you can see this is my first mockup, once i was happy with the angle i proceeded to weld the two parts together, one thing i was having problems with was my Mig, it was having none of it, i could not get the power/wire speed rite, it was either blowing holes in it or building on top, so please excuse my welding.
Next completed welded pipe
its functional rather than pretty at this stage,i have ground all the welds back and its better in the end but still far from perfect, on the MK2 i need to sort my mig out or possibly invest in a Tig, this is the excuse i need
finally the completed pair, please ignore one is longer as i have not cut its final length yet, both have had some heavy grinding but still fare from perfect.
