Originally Posted by opium89
Since the weather's cooled off, the Bird is getting harder and harder to start cold. At present the bike is finally idling on the third try. One thing I notice is that the idle is pretty low until after that third try then it keeps itself going. Anyone else having this issue? I'm getting close to the 500 service now, just waiting to take it in and have it looked at then.
BTW, I still can't get this freakin belt adjustment right. I went in again last weekend and cranked it down another quarter turn. The obvious CHIRP was gone after the first adjustment, afterwards turning in to a bit of a chatter coming out of first. Now after making it slightly tighter, it's developed a whine in second gear at about 2500rpm. I will be a happier camper when these two issues are solved.
you will find your engine is still very tight at your milage,also the T-Bird is different to all previous twins as in it does not have a manual fast idle, on the t-bird its automatic but does seem to take a bit longer to kick in, just give it a little throttle to keep it going a moment until it settles.
as for the belt you should not be having to much problems getting it roughly rite, there is a lot of room for error with the tension, it does not need to be perfect.
