Spark plugs for 2010 Thunderbird - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleMotorcycle.com Classifieds!Ontario Tourism
Old 10-24-2009, 02:07 PM   #1 (permalink)
Favourite Bike: 2010 Triumph Thunderbird
robertrichhart's Avatar
Question Spark plugs for 2010 Thunderbird
Since NGK doesn't seem to have an iridium plug for the TBird....anybody tried the Autolite XS4164DP as an alternative?
robertrichhart is offline   Reply With Quote
Old 10-24-2009, 08:52 PM   #2 (permalink)
Are you sure thats even an alternative, and if it is that it's not a standard plug? I ask because i researched the heck out of this subject because i loved irridiums with my speedmaster. and i couldn't come up with one alternative plug to ours that was a non-standard or high performance plug. I will certainly check it out tho. But man, getting to the plugs is a lot of work on this bike !
Old 10-25-2009, 05:33 AM   #3 (permalink)
Favourite Bike: Thunderbird 1700 Big Bore
mad_angler's Avatar
tbh guys its not worth concidering on the thunderbird as it already has two plugs per cylinder, even if one fails to spark the second will. no benefit to be had.
Thunderbird 1700cc Big Bore - There's No Replacement For Displacement
mad_angler is offline   Reply With Quote
Old 10-25-2009, 11:16 AM   #4 (permalink)
I thought about that already, but i'd still like to see how they work. iridiums made quite a difference in my speedmaster in several ways, and side gapping them was even better. I can see how 2 plugs per would make plus like that unnecessary but you never know for sure till you try.
Old 10-25-2009, 09:35 PM   #5 (permalink)
TBird Irridium plugs
The Autolite XS4164DP does show up as an irridium upgrade plug for the NGK DPR6EA-9 on the Autolite website. I know what you mean Daz... I sure noticed a difference on my America as well with the irridium plugs in place. I'd sure like to give some a try on the Bird.........
Old 10-25-2009, 10:40 PM   #6 (permalink)
If you side gap them, that is cutting a bit of the ground electrode off so the center electrode is not covered, that pretty much doubles the effect of the iridium. Angler may be right not just because of the 2 per cylinder, but some bikes don't seem to benefit from them. even bikes of the same models. I imagine thats probably due to the way the bike is tuned....pipes? Air mods? Etc. But as much as mine benefitted i really wanted to try them. so i may give those autolites a try.
Old 10-28-2009, 01:50 PM   #7 (permalink)
Favourite Bike: Triumph Thunderbird 1600
Baltothunder's Avatar
Other Motorcycle: '83 Honda Magna VF750C
Does the bird use NGK as stock plugs? If so I'll want to change them out after what happened to the Magna...Will never use them again if I can help it....
2nd Officer Harbor Chapter #215 Southern Cruisers Riding Club
Never take for granted what you have been given, and what you have earned....
Baltothunder is offline   Reply With Quote
Old 10-28-2009, 01:55 PM   #8 (permalink)
yes. But if an electrode popped off or some such thing, realize that thats not a common thing with KGK or any plugs. You were just unlucky whatever it was because there are no common issues with NGK. They are used in most every bike on earth !
Old 11-19-2009, 11:39 PM   #9 (permalink)
Favourite Bike: BB ThunderBird
Hey Mad_Angler....
About the two spark plugs per cylindar (4 total)...do I understand correctly?
AZfun
AZfun is offline   Reply With Quote
Old 11-20-2009, 09:38 AM   #10 (permalink)
mad_angler's Avatar
yep thats rite
New Ignition Coil, Spark Plug Wires and Iridium Spark Plugs...better performance? brownbomber Twins Talk 15 10-27-2009 04:25 PM
2010 Thunderbird jamscot Triumph, Models & Dealers 30 07-16-2009 10:30 PM
2010 Thunderbird almost here norton54 Twins Talk 76 04-01-2009 11:42 AM
spark plugs schmark plugs DaleE Hinckley Classic Triples 6 10-25-2005 11:54 AM
