field report six hours installing accessories
a couple buds and I spent 6 hours wrenching. good bad and ugly.
here is the short version:
longhaul dual seat: hard as H## to get the third screw lined up since it is UNDER the tail. need leave side 2 very loose, then force the seat forward and try not to let the soft naugahyde get cut with the tool which does not fit easily.. recommend a LONG EXTENSION on the allen wrench to protect your seat material.
sissy bar/luggage rack: what is the spacer for? no instructions, no idea unless it is a spanner for jigging. Kit was missing the sissy bar padded backrest....
brake cylinder cover: easy as pie.
mirror broke and is not adjustable any way I can see... the upper part that is apparently a snap-sealed unit.... need to replace.
roadster screen: side brackets needed redrilling to let carriage bolts pass through. Prolly sized right before chroming.. chrome is pretty hard to drill.
roadster screen side bracket upper mounting screw: mis aligned enough so that the skirt on the bolt did not allow to thread.. had to use the removed allen head screw, access WAY dificult for these size 9 hands.. took 20 minutes of swearing and finger mashing.
chrome glueons for caliper covers, speedo hood, and tank bag leather: easy sleazy.
rear sissy bar bag: pretty cheezy velcro attachments look like easy on and off is more important than bullet proofness. could not mount cause the sissy bar padded backrest was missing.
foot-rests front and rear: both sets were missing the attachment hardware from frame to bar.. could not mount. one set had missing clip, and a broken plastic shim..
dresser bars: rears easy sleazy.
front dresser bar: one side bolt really hard to reach, and it galled into the nut, making wrenching way too hard. I am too experienced to ascribe it to cross threading.
windshield mechanism: slick as clintons cigar.
seatback for rider backrest: excellent design, but not a readily detachable on/off. takes four bolts and seat removal...
oil dipstick: looks good, but it is not gonna be touchable on a hot bike..The original one was cheaper than the one on my lawnmower.
Rotation of handlebars to an inch-two inches higher for upright seat posture on my 6 foot long armed frame: easy as pie, but needed to rotate the controls back down for mirrors to work. thats when the mirror broke. flops like a drunk dick.
Final impressions: Think I will return the foot rests for rider, as the pegs already drag enough to make we worry about turning.. will let my pillion decide she wants the passenger foot rest or stay with the simple pegs.
Total weight installed parts was 50 pounds or more. with the windescreen aka buffet-screen, it is a bit more sluggish. but styled out well.
in my opine, the rear sissy and luggage finish the lines to make it a much longer looking bike.
blue for beginners, black for slow. mine is silver for speed and show!!
