BikeBanditTriumph DetroitSoupy's PerformanceRicor ShocksOPP RacingTrident-Exhausts.comCommonwealth Motorcycles
Penn Foster
Old 10-02-2009, 11:06 AM   #1 (permalink)
Favourite Bike: Triumph Thunderbird 1600
Baltothunder's Avatar
Other Motorcycle: '83 Honda Magna VF750C
Steering lock?
Hello all. Just another new Thunderbird owner here. I haven't been able to quite figure out the steering column lock on it yet. Bars turned fully left, insert key, press in and twist counter clockwise, but nothing seems to catch.
What am I doing wrong?
Baltothunder is offline   Reply With Quote
Old 10-02-2009, 11:39 AM   #2 (permalink)
After you turn it fully, as you are tryin to turn the key move the bars back and fourth a bit. The problem you have is the hole isn't aligning perfectly with the pin. Just wiggle the bars around till you feel the key turn more. You'll feel it. And realize that it ALSO has a harley type fork lock too, the type thats just two loops for a padlock to go thru. Thats a far safer and harder to crack one for those places you need more security. Steering locks are considered easy to break by yanking the bars hard a few time. i assume that may not be true if they are beefy enough. But the padlock one is likely to be sturdier and using both woul make it REALLY hard.
Oh, and congrats on the Tbird purchase !
Happiness is Cycleworld's "Best in class" cruiser, the Triumph Thunderbird. Here's mine.
Old 10-02-2009, 12:46 PM   #3 (permalink)
Thanks! Only had it a day and have already had obout 5 people walk up to talk about. Will probably go the padlock route and just stow it in my jacket.
Old 10-05-2009, 03:18 PM   #4 (permalink)
Favourite Bike: 07 Bonnie Black
Derby Boy's Avatar
Other Motorcycle: 93 Yamaha GTS
Extra Motorcycle: can't afford another
If the steering lock is the same as on the Bonnie, then hang the key in your laundry room and buy a disc lock. It's not the getting it locked issue, it's the fear of breaking off the key trying to get it unlocked. Some Bonnie owners have had this issue.
"Another Trumpet Rat enslaved to a Bonnie"
07 B/B, AI gone, Emgo 60's Cocktail Shakers, K&N air, 40/137, 1 shim, Airbox gutted, Bar end Nap's, +1 risers, Custom gauge bracket, never ending tinkering
Derby Boy is offline   Reply With Quote
Old 10-05-2009, 03:23 PM   #5 (permalink)
Favourite Bike: 2010 Triumph Thunderbird
Other Motorcycle: 1980 Triumph Bonneville
I couldn't get my steering lock to work at all...realized (ala dazco earlier) that the handlebars needed to be turned back just a hair in the other direction and the locking pin slid right into place. With just a little twist either way...it locks or unlocked effortlessly. I still agree that a padlock is probably most secure...but in a pinch, the steering does actually function in my experience.
traveler501 is offline   Reply With Quote
Old 10-13-2009, 06:18 AM   #6 (permalink)
Favourite Bike: TBird 1700
Birdy68's Avatar
Other Motorcycle: '95 Tiger 900
Go The Full Hog....
Pad Lock and a Mother of a Chain!
Pad Lock the steering with the chain and then onto a tree...
In the words of dear Mr. Punch, "that's the way to do it!"
Birdy68
-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-
Leave the pork pies for now - get the sausage rolls while they're hot!
Birdy68 is offline   Reply With Quote
Old 10-13-2009, 10:27 AM   #7 (permalink)
This is a Tbird we're talking about here birdy. Nothing less than a hired guard in a machine gun turret will do.
Old 10-20-2009, 03:25 AM   #8 (permalink)
Favourite Bike: Speedmaster 2004
Other Motorcycle: Thunderbird 2010
Cool
Same here, and then sometimes you just canīt get the key in itīs place and that is even more disturbing if the bike is locked and you canīt open it! Perhaps by time it loosens up and
starts to function. On the Speedy itīs nice and loose.
Hey! thatīs not the Birds fault.
Iīll get a padlock and a few meter chain.
Speedmaster 2004 in Espoo, Finland (summer)
Thunderbird 2010 in Oceanside, San Diego County, Ca (winter)
IBA Finland SS1000
PappasGarage is offline   Reply With Quote
Old 10-20-2009, 08:05 AM   #9 (permalink)
Newbie
Favourite Bike: Black Thunderbird 1600cc
All of the above is correct but once u have twisted the key counter clockwise, try turning the key clockwise just a little bit, while it is still pressed in, then u should be able to withdraw the key and it should remain locked, it worked for me!!
Tester is offline   Reply With Quote
Old 10-20-2009, 01:02 PM   #10 (permalink)
Favourite Bike: My own
My steering lock was super sticky at first and I had a heck of a time trying to get it to work. I almost snapped the key off trying to loosten it up. However, after a bit of persistence it has totally loostened up and works perfectly. Just remember to keep the wheel fully cranked to the side when pushing the key in.....then move the bars ever so slightly, turn the key until you feel it catch. The same goes for unlocking.....push the key in then slightly move the bars and the key should spring back.
They must be on the tight side from the factory and then free up with use. That's the way mine was anyway.
Truss is offline   Reply With Quote
Steering lock tshadow6 Twins Technical Talk 16 07-28-2009 04:08 PM
Steering Lock Key bonza Twins Technical Talk 11 07-13-2008 10:10 PM
T3 Steering Head Lock Nut bobbo Maintenance & Workshop Talk 4 06-27-2008 05:02 PM
Steering way: Degrees of steering lock ChuckofTahoe Sprint Forum 9 09-02-2007 09:35 PM
steering lock bird900 Hinckley Classic Triples 8 12-09-2004 09:28 AM
