The REAL lowdown on BB kit warranty - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!New Bonneville
Old 09-22-2009, 05:48 PM   #1 (permalink)
Unless Peter at Triumph USA is wrong, the warranty works like this....
As far as LABOR costs, the warranty IS good when the BB is installed after you take delivery. However, it is not good for the full 2 years unless done before delivery. The warranty simply follows the bikes original warranty. For example, if the BB kit is installed 6 months after you take delivery, then the warranty on the kit is 1.5 years long. So basically all it means is that your bike has a 2 year labor warranty and if you get the BB nothing changes as that goes. If it's installed 1 day before your bike's warranty is up, your BB kit's warranty is good for 1 day. Get it?
Thats said, the warranty on PARTS is good for 1 year regardless of when it's installed.
And i'm not saying It's impossible that peter is wrong, but if HE can't be trusted then we'll never know till someone has to use the warranty. But if you think about it the above scenario makes total sense, so i think it is indeed the correct policy. But you also have to figure that is the mechanic does something wrong it's probably going to be obvious right away or very soon. And if the parts are defective you're covered for a year no matter what.
Old 09-22-2009, 06:32 PM   #2 (permalink)
Favourite Bike: Thunderbird 1700 Big Bore
mad_angler's Avatar
thats exactly how i understood it worked
Thunderbird 1700cc Big Bore - There's No Replacement For Displacement
mad_angler is offline   Reply With Quote
Old 09-23-2009, 07:44 AM   #3 (permalink)
Favourite Bike: Hmmm? Tough one.
OKCTriple's Avatar
That might be the case but a reputable dealer would surely warranty their work for at least 6 months.
Other bikes: 2005 Thruxton with 904 Wiseco big bore kit, BC stage one cams, CR carbs & BC Predators, 2010 Husaberg FE390, 2010 Triumph Thunderbird 1700, 2009 Kawaskai ZX-6R, 2011 Kawasaki Ninja 1000.
OKCTriple is offline   Reply With Quote
Old 09-23-2009, 10:07 PM   #4 (permalink)
Favourite Bike: 2012 Daytona 900
Brooksie's Avatar
Other Motorcycle: 2008 Kawasaki ZX14
But they don't HAVE to provide any warranty outside of the bike coverage. Good luck getting that covered if a dope puts it in.
Brooksie is offline   Reply With Quote
Old 09-24-2009, 08:23 AM   #5 (permalink)
OKCTriple's Avatar
Obviously you discuss it with them and get it writing so that you don't end up with the dope.
Old 09-24-2009, 11:07 AM   #6 (permalink)
You're both right to a degree. Lets face it, nothing is written in stone here and dealers vary as wildly as the personalities that run them. So one dealer may tell you to pi$$ off if you ask for a warranty past where it technically would be, and some others may say sure. I seriously doubt many will put it in wring tho. My issue with it is not just mechanical but i fear the cases will get scratched up removing the engine and that few if any dealers are gonna agree to making good on that unless the scratches are major. But like i said, it depends on the dealer and they do vary a lot in the way they do business.
Is that the REAL HVT or rodburner Twins Talk 13 08-07-2006 05:28 PM
It's been real. d2mini Twins Talk 26 06-30-2006 07:41 PM
MCJ - Is it real? Nunzio Speed Triple Forum 15 06-28-2006 10:51 PM
The lowdown on customs duty if u wanna order pipes from TB dazco Twins Talk 15 08-18-2005 06:37 PM
Oil - Is This For Real? Archimedes Twins Talk 9 07-16-2005 08:24 AM
