BB install question - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-21-2009, 03:18 PM   #1 (permalink)
Favourite Bike: '10 Thunderbird
BB install question
In thinking about the pending BB install I wondered if I would have another break in period to deal with after the install. Certainly much of the internals will be the same, but with new pistons, sleeves and cam is there enough new bits that I'll be back to dealing with a break in period as well as an early oil change?
Any thoughts?
Thatch is offline   Reply With Quote
Old 09-21-2009, 03:34 PM   #2 (permalink)
Absolutely. And i'm sure the dealer will tell you to do the 500 mile service, tho this time it only needs to be oil change so you can do that yourself. breakin is mainly to seat the rings and since the liners pistons and rings are all new, breakin is just as crucial.
Old 09-21-2009, 04:53 PM   #3 (permalink)
Well, I thought as much. Makes sense of course, just hadn't really put it on my radar up to now.
Old 09-21-2009, 06:13 PM   #4 (permalink)
Favourite Bike: Hmmm? Tough one.
OKCTriple's Avatar
After having he BB kit installed in my Meanstreak the manufacture "Thunder MFG" recommended riding it like normal. The kit included pistons and cams like the Triumph kit. Myself, once installed I will take it easy for about 100 miles then flog on it to make sure the rings are sealed. All other parts of the engine will be broke-in the only thing to wear in after the BB kit install is the piston rings, cam lobes and journals, first 100 miles will take care of the cams. However, the Mfg and the dealer do recommended changing the oil after 500 miles of operation.
Other bikes: 2005 Thruxton with 904 Wiseco big bore kit, BC stage one cams, CR carbs & BC Predators, 2010 Husaberg FE390, 2010 Triumph Thunderbird 1700, 2009 Kawaskai ZX-6R, 2011 Kawasaki Ninja 1000.
OKCTriple is offline   Reply With Quote
Freak install / AI question sharp21 Twins Technical Talk 10 01-14-2009 01:12 AM
o2 install question RT Tiger Workshop (archive) 6 01-15-2008 05:03 PM
Gen Mar Install Question 05+ crashdb Sprint Forum 7 05-09-2007 09:44 AM
Tach install question zmilin Twins Technical Talk 4 03-09-2007 06:28 AM
Gaiter Install Question boboso Club Cafe' 0 06-29-2005 09:03 PM
