my Bird arrived Friday and am not able to pick it up until tomorrow. The dealer had a big open house celebration and parked my bike on the showroom so they could show it off (with a sold sign on that said "Do not sit on, SOLD") Anyway, I stopped by to see it and they started it up so I could hear it. When they did they had to crank on it for quite some time and then when it first fired off it would not stay running. The second time it fired off normally and then idled a bit rough at first, then settled into an idle.
I suspect you may have a small vacum leak that is causing you bike not to idle. I'm sure they'll find it when you bring it in for service.
Other bikes: 2005 Thruxton with 904 Wiseco big bore kit, BC stage one cams, CR carbs & BC Predators, 2010 Husaberg FE390, 2010 Triumph Thunderbird 1700, 2009 Kawaskai ZX-6R, 2011 Kawasaki Ninja 1000.
