Modify Airbox on TBird? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-26-2009, 10:41 PM   #1 (permalink)
Favourite Bike: 2010 Triumph Thunderbird
robertrichhart's Avatar
Question Modify Airbox on TBird?
Can the airbox on the TBird be drilled out at the bottom like on the Speedmaster/America? If so, has anybody tried this yet and installed a K&N or Uni? Wondering if the EFI can adjust without a remap for this modification???
robertrichhart is offline   Reply With Quote
Old 08-26-2009, 10:54 PM   #2 (permalink)
Favourite Bike: 2010 KTM Adventure 990 R
Rayzor61's Avatar
Other Motorcycle: 05 Speed triple (4th one)
Extra Motorcycle: Working on it!
If you drilled out the bottom of the air box you'll hit china dude! Removal of the built-in seat baffle is key. Get out your chainsaw and let us know how it goes.....hehehe
Rayzor61 is offline   Reply With Quote
Old 08-27-2009, 11:33 AM   #3 (permalink)
It can't be done like on the america/speedy. It COULD be somewhat, but the amount of intake area gained would be about 1/4 as much if that. the reason is hard to describe, but in short the bottom of the filter sits on a 1" high protrusion at the bottom of the box that is about the size of an egg or even less. So you would have to put a piece of foam around it as a seal sonce the foam on the bottom of a UNI will not be touching it. That would eliminate 25% of potential area right there. So you'd end up with a oblomg hole maybe 1/2 the size of a small egg.
the other issue is that any mods we do will not be compensated for by the EFI unless 1)-you get a power commander or such and have the bike custom tuned, or 2)-it happens to be a mod someone else has created a map for and your bike has provisions for loading that map.....in other words, if it's custom you need the device it was made with....PC or tubeboy.
Old 09-20-2009, 03:20 PM   #4 (permalink)
Question TBird Airbox Mod???
OK, so its been a few more weeks and several more TBirds have new homes... Has anybody done any airbox mods they would like to share results on?
Old 09-20-2009, 03:53 PM   #5 (permalink)
No one is going to do anything like this yet because the EFI will not compensate for more than a small change. And as of yet we have no way to tune it unless tuneboys can be used w/o a bike specific model. But someone wouls still have to create the map. And the power commander for the Tbird isn't out yet. So the only thing you'd accomplish by modding it would be to make the bike too lean and thereby risking engine damage. A small increase CAN be compensated for automatically by the system, but if you mod the box it's gonna be much more than that or it would be worth doing anyways. In short, we have to wait. Bike is too new yet.
Old 09-20-2009, 04:00 PM   #6 (permalink)
Favourite Bike: '10 Thunderbird
Daz, I'm not sure I have a complete grasp on the new world of EFI , but, I was thinking that if an increase intake was balanced with exhaust that the there wouldn't be a problem with the tune. I've no idea though. This is the sort of thing I'd feel much more comfortable being back in the land of carbs. I was thinking that once the bb kit and bc pipes with cat bypass in that I could make use of a lot more intake.
That Power Commander 'auto tune' is going to come in really handy I'm thinking.
Thatch is offline   Reply With Quote
Old 09-20-2009, 04:07 PM   #7 (permalink)
Favourite Bike: TBird 1700
Birdy68's Avatar
Other Motorcycle: '95 Tiger 900
Originally Posted by Thatch View Post
... That Power Commander 'auto tune' is going to come in really handy I'm thinking.
If I'm going to venture down the dark path, then the PC-V 'auto-tune' is the route for me!
Birdy68
-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-
Leave the pork pies for now - get the sausage rolls while they're hot!
Birdy68 is offline   Reply With Quote
Old 09-20-2009, 04:13 PM   #8 (permalink)
Things are the same as with carbs. The degree to which the exhaust is restrictive isn't the point here tho. The exhaust needs to be less restrictive if increasing the volume by increasing the amount of mixture, yes. But that aside, ands assming you have TORs or whatever, at the intake end of things what i was saying is that if the EFI doesn't compensate for the extra air in the mix then the bike would run lean if you don't map it for that. Just like when you do airbox mods on a carb bike you have to change the jetting. Only here we can't do that till we have the devices we need to, power commander or whatever. And yes, that autotune may end up being a godsend if it turns out to truly be what the name implies. Especially for you with a BB and those pipes and no map available for use with both. You'd have to have it dyno tuned, but with auto tune you could pass that step AND be ready if you happen to change things yet again in some other way that alters the fueling needs.
airbox part number 2000 tbird legend Spyke Hinckley Classic Triples 1 07-30-2006 02:12 PM
Sprint airbox on a tbird carpelux Hinckley Classic Triples 1 12-11-2005 09:18 PM
TBird Airbox Drain tube/plug mecscc Hinckley Classic Triples 5 03-07-2005 10:22 AM
'98 Tbird fried carb sliders with a well cooked airbox Hinckley Classic Triples 22 01-10-2005 03:37 PM
