Alternative to Triumph Saddlebags - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comSportbikeTrackGear
Old 09-26-2012, 07:21 PM   #21 (permalink)
Main Motorcycle: Thunderbird Storm 2012
Deanno's Avatar
Other Motorcycle: Had a 2010 America
The solo long haul does not have a backrest accessory.
Deanno is offline   Reply With Quote
Old 10-13-2012, 11:23 PM   #22 (permalink)
L50
Main Motorcycle: McQueen SE
Fernando, the bags look awesome. I wish they made them for the bonneville. I am still searching for bags to go on my mcqueen
L50 is offline   Reply With Quote
Old 11-22-2012, 10:10 PM   #23 (permalink)
Main Motorcycle: 2011 Thunderbird Storm
Fernando's Avatar
Other Motorcycle: Ducati 998
L50 - give them a call at Leatherworks. If they don't make something for your bike, maybe they will if you tell them what you are looking for. Worth a shot anyway.
Fernando is offline   Reply With Quote
Old 11-22-2012, 10:29 PM   #24 (permalink)
geoff c's Avatar
Other Motorcycle: Tell him he's dreaming
I have the QR sissy bar on my Thunderbird and want to mount saddlebags using easy brackets.
Do the bags end up outside of the shock absorbers, so any bags with rigid flat backs will fit?
I can't quite be sure from the photos.
Originally Posted by Fernando View Post
geoff c is offline   Reply With Quote
Old 11-23-2012, 02:03 AM   #25 (permalink)
Main Motorcycle: Triumph Thunderbird
I have the QD backrest and EZs. I don't believe a flat backed bag will clear the shock. The SlimBags I got have a cutout for the shock. If you took a 1/4 inch piece of plexiglass and cut it to fit between the EZ and bag as a spacer, it would clear the shock. Come to think of it you might be able to get slightly longer bolts with the EZs and put some washers behind the EZ mounting spindles. The EZ bolts are special for the triumph backrest so EZ should be able to tell you what size bolts to get to accommodate a spacer.
dougl is online now   Reply With Quote
Old 11-23-2012, 02:27 AM   #26 (permalink)
geoff c's Avatar
Thanks for the heads-up Doug, I'll make sure that I get bags with a cut-out for the shocks or ones that will fit between the shocks and the indicators.
Old 11-23-2012, 10:47 AM   #27 (permalink)
Fernando's Avatar
The reason I went with the dimensions of the 112+2 saddlebag is it fits between the shock and the rear turn signals. You just have to be careful where you attach the EZ Bracket to the saddlebag.
The below images show the placement of the bracket on the bag and the space between the bag and the rear turn signals. There is roughly between 1/8" to 1/4" between the shock and the bag.
Old 11-27-2012, 06:11 PM   #28 (permalink)
Main Motorcycle: 2012 Triumph Storm
Other Motorcycle: 2012 Kymco 500
Fernando, thanks for all the pictures. Hard work that will be appreciated by many including me. I don't really like saddlebags on the bike all the time and this seems like a good compromise.
colombianstorm is offline   Reply With Quote
Old 12-05-2012, 07:03 PM   #29 (permalink)
Deanno's Avatar
Has anyone EZ mounted the Hardstreet Classic Tourer bags to their Bird, rather than the Slimbags?
Alternative to the Triumph Sissy bar BigNoseG Thunderbird Cruiser Chat 11 06-04-2013 01:08 AM
Alternative Triumph ECU Application PVO22 ECM and FI Tuning - Help, Tips & Tricks 4 02-12-2012 04:41 AM
Triumph Saddlebags for a 2000 Triumph Sprint/955i prtaves Sprint Forum 7 01-26-2010 11:00 AM
Rizoma / Triumph fat bar alternative. w00ht Speed Triple Forum 9 05-06-2008 12:26 PM
triumph adventurer saddlebag support alternative Hinckley Classic Triples 0 08-07-2004 01:43 PM
