Gas Cap Almost Impossible to Remove - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Motorcycle.comNew Bonneville
Old 11-03-2009, 10:44 AM   #1 (permalink)
2010 Tbird, I dread getting gas because it takes a tremendous amount of strength to get the cap off. Anyone else experience this? Any cure? Any alternatives?
aglazen is offline   Reply With Quote
Old 11-03-2009, 10:56 AM   #2 (permalink)
Favourite Bike: '10 Thunderbird
It can be tough. It does loosen up after time. I just made sure that I took the cap off while still wearing my gloves at first. Now it doesn't matter and the cap comes off fairly easily.
Thatch is offline   Reply With Quote
Old 11-03-2009, 10:59 AM   #3 (permalink)
ROSCOE69's Avatar
do you feel its a vacuum problem or to much friction from the rubber seal ? are you pushing down hard enough when you turn it. try a little grease on the seal.
ROSCOE69 is offline   Reply With Quote
Old 11-03-2009, 11:07 AM   #4 (permalink)
Mine was the same for about the first maybe 10-20 times i fueled up. Not every time, but occasionally. i'd say it happened about 5 times. then it loosened up and has never happened since. If yours is happening a lot you may wanna spread a little oil on the seal like you do on an oil filter. Not sure if that'll work, but it's a thought.
Old 11-03-2009, 12:01 PM   #5 (permalink)
kraftdinners's Avatar
Yup I have a struggle with it as well, its bloody ridiculous !! thought about a lube myself but was wondering if the lockable gas cap is the same, if not then a cork ;-)...
Alan
kraftdinners is offline   Reply With Quote
Old 11-03-2009, 12:26 PM   #6 (permalink)
Favourite Bike: 2010 Thunderbird -Blue/Wh
DOUBLEL's Avatar
Location: SLIDELL, LA USA, In The Eye of Hurricane Katrina
Mine has loosened up a bit. Still best to open while wearing the gloves. It is just like the America was. If finally got better, but you really feel dumb sitting at the gas pump with your friends around you you're struggling to get the cap off.
Aside from wearing in and getting easier, pushing down while turning is the only solution. I probably wouldn't have minded it being about a 1/8" higher so you could grab it easier.
DOUBLEL is offline   Reply With Quote
Old 11-03-2009, 05:21 PM   #7 (permalink)
Favourite Bike: 2010 Triumph Thunderbird
engage's Avatar
For what's it's worth, I have the locking gas cap and have no problems.
engage is offline   Reply With Quote
Old 11-03-2009, 07:19 PM   #8 (permalink)
Favourite Bike: Triumph Thunderbird
hypervista's Avatar
Ditto what Thatch, dazco and others have experienced. Mine was somewhat difficult at first, but over time it loosened up a bit. I don't even think about it now.
I would like to get one of those "pop up" gas caps, though.
hypervista is offline   Reply With Quote
Old 11-04-2009, 12:07 AM   #9 (permalink)
I have the locking gas cap which I think is actually for a Bonnie, never had this problem.
31712 is offline   Reply With Quote
Old 11-04-2009, 08:56 AM   #10 (permalink)
Favourite Bike: Thunderbird
It is a vacume problem.
Heres the cure
When putting the cap back on spin it until it stops. Twist until it clicks once then stop.
any more and the vent holes are blocked. Thats what the dealer told me anyway and it works for me.
DruAde is offline   Reply With Quote
Insurance impossible Espen36 RAT - United Kingdom 7 04-08-2008 05:41 PM
Mission Impossible Scrambler pics MattTriumphs Twins Technical Talk 6 04-22-2007 05:15 PM
Mission Impossible LIJ Twins Technical Talk 0 02-10-2007 03:36 AM
Mission Impossible 3 piston Twins Talk 15 05-07-2006 10:05 AM
New '03 Daytona vs. the Mission Impossible Years scrobbins Daytona Deliberations 11 08-29-2003 02:18 AM
