2007 Bonneville Won't Start - Triumph Forum: Triumph Rat Motorcycle Forums
The Welcome Center New to the Site? Please take a moment to introduce yourself. New members and members who have yet not posted MUST post their first post here to activate their profiles.
Old 11-27-2012, 10:17 PM   #1 (permalink)
Newbie
Main Motorcycle: 2007 Bonneville
Replaced the original battery, new plugs, cleaned carbs.
Problem started after a short ride with sudden & total loss of power. Started again after 5 minutes, ran less than a minute stalled out again. Pushed it home. Started right after I re-installed carbs and ran long enough to rev a few times and adjust idle speed and seemed all good again then I shut it off. Thought I fixed it. Hasn't started since. Turns and turns and every so often gives one sputter like it wants to start but doesn't. Ran perfectly for 17k miles since I bought new. Always serviced including a costly valve adjustment by the dealer 2 years ago. Always use good gas etc....Didn't run it much this summer however when I did it ran right (until it stopped running).
Read a post about testing resistance through the plug leads and did so. Post said I should have seen 18k but I read around 12k. It suggested replacing the coil so I ordered the Nology coil today. I am not a mechanic by any stretch but am confident I can change the coil without a problem. Just not sure I am on the right track.
Any thoughts either way would be appreciated. I bought another bike in the spring and think the Bonneville is just pissed about it so I am being punished for the indiscretion.
Plamb is offline   Reply With Quote
Old 11-29-2012, 01:53 AM   #2 (permalink)
Main Motorcycle: 09 Triumph Bonneville
Other Motorcycle: 08 Victory Hammer
You could try the twin talk section.
goat-ee is offline   Reply With Quote
2007 S3 - just started dying and then will not start.... vegas thruxton Speed Triple Forum 11 09-09-2011 01:52 AM
2007 No Start...faulty ecm? cam3281 Daytona675 Forum 2 10-05-2009 09:08 PM
2007 Speed Triple Will Not Start raydeje Speed Triple Forum 19 09-14-2009 08:36 PM
1-3 and now 1-4 - what a start to 2007! TonyD Biker Hang-Out 3 01-10-2007 03:41 AM
My 2007 sprint wouldn't start chefjohn Sprint Forum 1 01-08-2007 01:56 AM
