68 Trophy 650 in process of upgrade/restoration - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com
The Welcome Center New to the Site? Please take a moment to introduce yourself. New members and members who have yet not posted MUST post their first post here to activate their profiles.
Old 11-17-2012, 07:43 PM   #1 (permalink)
Main Motorcycle: '68 TR6r
h20rider's Avatar
Hello to all
Now down to business.
I just tried to replace a ratty rectifier and Zener diode with a Tympnium.
The bike caught, ran a little, died and now will not start. I think it died simply because I didn't adjust the choke satisfactorily.
I checked the points and they seem to be functioning, as in, opening and closing. I checked the connection on the Tympanium....they seem correct.
I pulled the plugs, hand cranked the motor, but saw no spark actress the gap.
I tried reconnecting the original rectifier and Z diode. Still no visible spark....but on that attempt, I felt a bit of a charge through my fingers. I don't know if the same thing happened with the Tympanium.
Finally, while the Tympanium was still installed, once when the open connector wire for from the Z diode brushed the frame, there was sparking from the open wire.
Yes, there is gas and the key is on. All the start-up routine was done.
The plugs, plug wires, etc. we're all functional just prior to the changeover....so no reason to doubt them. I'm not sure how to verify that the stator, etc. functions....but, it was all working yesterday.
Ideas?
h20rider is offline   Reply With Quote
Old 11-18-2012, 07:47 PM   #2 (permalink)
h20rider's Avatar
Okay...replying to myself, but I tried some diagnostics.
Pulled white wires from coils and checked terminal across ground--- meter registered.
Checked voltage across both sets of open points...approx. 12 v each
Checked both terminals of the ammeter and across the terminals....okay
Voltage from Zener lead to ground = 12
Checked ignition switch leads to ground.....all three came up at 12v....seemed odd. (?)
Still no obvious spark when connected plug held to block while kick starting.
Fuse still intact.
If I were at least getting spark, I'd move on to the fuel system, but....
The lights are wonky.....fuse blows when high beam twitch is thrown....even nought no headlight going on...even a low beam. Brake light works, but once activated my result in the taillight remaining on.
Ideas?
valve guide tr6r trophy 1970 restoration whompa73 Member's Restoration & Rebuild Projects 4 02-07-2012 03:49 PM
Want to Upgrade Triple Sidestand to Trophy,is this the correct one? mznyc T3 Sport / Touring Forum 8 09-08-2011 06:06 PM
1969 T100C - Trophy 500 Restoration Shutt24 Member's Restoration & Rebuild Projects 60 09-29-2009 09:56 AM
'93 Trophy brake upgrade freck Maintenance & Workshop Talk 1 04-01-2008 11:21 PM
95 trophy restoration TWOWHEELSONLY Trophy 6 03-28-2006 05:11 PM
