New Member - Bonnevile Low Battery Problems - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Motorcycle.com
The Welcome Center New to the Site? Please take a moment to introduce yourself. New members and members who have yet not posted MUST post their first post here to activate their profiles.
Old 11-17-2012, 07:29 AM   #1 (permalink)
Newbie
Main Motorcycle: Bonneville
Hi All,
Bonneville starting problems.
Just checking if anyone knows of a way to reset the minimum voltage level below to 12.6 volts using tuneboy or similar.
I have an 09 Bonneville in London, used mostly daily and have been having constant non starting problems due to battery voltage dropping below 12.6v
I have just paid £56 to have the 'City Tune' so that the EFI systems shuts down immediately after turning the bike off. This was done 10 days ago and already I have had the same non starting problem so this has not cured it.
If there was a mod that set the low voltage threshold a volt or so lower then this would solve the problem.
I don't have off street parking, being in Central London, the bike is parked in the street so I can't easil plug the bike in to charge overnight, but have to remove the battery to do it.
This is the newest bike we have had and was supposed to be a good, new, reliable bike. My old 1984 BMW R65 was more reliable at starting.
I can't do the mod to the starter relay, parking it on the street and making it easliy nickable is not an option, even though I chain it and it is alarmed.
Any help Triumph?
Andy P is offline   Reply With Quote
Old 11-21-2012, 02:30 AM   #2 (permalink)
Main Motorcycle: Triumph Bonneville SE
I have a similar problem with a 2011 EFI. My cure has been to start using the choke, or a gentle twist of the throttle. The owners manual states always use the choke when starting, 2 clicks in cold weather and 1 click in warm weather, or with a warm engine. Doesn't fix the problem, but at least it always starts.
nzkiwi is offline   Reply With Quote
Old 11-22-2012, 08:31 PM   #3 (permalink)
Main Motorcycle: 2012 Bonneville SE
Exact same problem with my '12 SE. It doesn't do it every time but when it does I push the starter and it'll turn over once and stop even while I keep the starter pressed. I'll then pull out the "choke" one click and it starts right up, even when it's warm.
Sent from my DROIDX using Motorcycle.com Free App
sparky57 is offline   Reply With Quote
Old 11-22-2012, 09:25 PM   #4 (permalink)
Main Motorcycle: Bonneville se
mr1bienvenu's Avatar
Is this something that reprogramming the ECU can fix ? I don't know why but I have never had this problem and I let my bike sit up for months at a time during the winter with no charger on it.
mr1bienvenu is offline   Reply With Quote
Battery problems...... The_cat Maintenance & Workshop Talk 1 08-25-2009 06:21 PM
D12 Battery Problems spellbinder Daytona Deliberations 4 04-11-2009 09:33 AM
Battery Problems Newby Daytona Deliberations 11 08-29-2007 11:49 PM
Battery Problems - HELP! wongl10 Twins Technical Talk 8 08-20-2007 03:18 PM
Battery problems zippythehog Maintenance & Workshop Talk 4 09-14-2006 01:43 PM
