Manifold Upgrade, Acessory Mufflers +20 Hp? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-13-2008, 05:01 PM   #1 (permalink)
Lee
Multi-Iron Butt Moderator
Favourite Bike: Triumph RIII Graphite
Lee's Avatar
Other Motorcycle: Honda Goldwing 2012 Red
Extra Motorcycle: Is it really ever extra..
Yes I know we have talked about mufflers and losing the cat box. I want to know what you guys think about what the dealer has told me. he says that there is a 50 pound reduction in weight and about a 20 horse power increase with the manifold upgrade and the new accessory mufflers. (Manifold upgrade $350. + Accessory Mufflers $495. + Labor 3 hours $270. ) Total cost with tax about $1200.00
Is this true and is the cost resonable is what I want to know. Is there an alternative that is less costly and achieves the same end? Power and a little more roar from the RocKet.
I know when I tell the wife about the cost I will be hearing a lot more noise. Please let me know what you all think or recommend. Thanks Lee :
Four Iron Butt Rides Todate....Will Be Working On Longer Ones In The Upcoming Year...Jersey Born and Raised........Texas run 1000 in 24 hours in April 2012
Lee is offline   Reply With Quote
Old 05-13-2008, 05:30 PM   #2 (permalink)
Favourite Bike: 2006 Rocket III Classic
Pig9r's Avatar
Maybe some truth with the addition of a PCIII or Tuneboy. There are several other alternatives out there for more and less than that. So shop around.
Old 05-13-2008, 11:42 PM   #3 (permalink)
After cat-box delete and TORs mine dyno'ed at 139RWHP. The addition of Jardines and PC3 brought mine up to 150RWHP. Mine is an '05.
Are you talking about the newer R3T? I could see 20HP there because they come out of the factory with less HP.
Ride hard, die old.
drtim is offline   Reply With Quote
Old 05-14-2008, 04:48 PM   #4 (permalink)
Lee
Lee's Avatar
I have graphite Gray and the only year that it was made was 2005.
Old 05-14-2008, 05:04 PM   #5 (permalink)
wieght
Loose cat box save ten lbs, header and muffs loose another 20 lbs
trumpete is offline   Reply With Quote
Old 05-14-2008, 06:35 PM   #6 (permalink)
Thumbs down
AS per usual your dealer is a lying to you. The entire stock exhuast does not weigh 50 Lbs.And no way will you gain 20 HP. Tell him you want proof. Be there when they take off your stock system with a scale.HAHA Plus there off roads sound like shet..
busajack is offline   Reply With Quote
Old 05-14-2008, 06:36 PM   #7 (permalink)
Thumbs down
Yea add another 500 and see what your wife says.
Old 05-14-2008, 08:21 PM   #8 (permalink)
Lee
Lee's Avatar
I already know what she would say and it would not be very pleasant!
Old 05-19-2008, 05:44 PM   #9 (permalink)
Any dealer that charges more than an hour and a half is taking advantage of you. You should and can do that job in an hour easy, including the re-tune.
2004 Sprint RS
Caspian Blue
SprintRide is offline   Reply With Quote
Old 05-20-2008, 02:26 PM   #10 (permalink)
Regardless what all this crap weighs, you can expect about 140 peak hp and 150 peak ft lbs of torque with the TOR/cat bypass setup and Tuneboy software to remove the restrictions from the secondary plates. This restriction even with the TOR/cat bypass setup and Triumph stock tune is about 12 ft lbs in the peak torque range (2500-3000 rpm). If you want to know how much of an improvement this could represent, have your bike dyno tested at a reputable DynoJet center. It should cost less than $50.
dougl is offline   Reply With Quote
Scrambler TOR mufflers vs Thunderbile powersports mufflers Davorallyfan Twins Technical Talk 18 08-20-2009 01:18 AM
New guy here! '98 Thunderbird Sport Mufflers upgrade Devon Honda Triumph Hinckley Classic Triples 26 05-14-2008 06:47 PM
New guy here! '98 Thunderbird Sport Mufflers upgrade Devon Honda Triumph Maintenance & Workshop Talk 1 04-08-2008 08:29 PM
Help, what manifold is this? Slinky Hinckley Classic Triples 10 03-10-2008 03:12 PM
How to install an acessory power NewSwede Twins Technical Talk 2 08-15-2007 04:00 PM
