Power Commander & Triumph Tunes - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-15-2008, 09:08 PM   #1 (permalink)
Does the current installed factory tune in the bike's ECU have to be a stock tune for the Power Commander to work properly using Dynojet's PC3 online download ??
Thanks
jeep is offline   Reply With Quote
Old 04-15-2008, 11:02 PM   #2 (permalink)
Favourite Bike: 2006 Rocket III Classic
Pig9r's Avatar
I seem to remember someone from dynojet saying they used a bone stock Rocket to do the map, which at the time had the 20050 tune. So yes, you would need the stock basic tune.
Old 04-16-2008, 02:34 AM   #3 (permalink)
Thanks that seems to make the most sense. I had a previous PC3 installed with the bike tuned with a previous factory Triumph tune Tor's and bypass & the bike ran poorly.
Old 04-16-2008, 10:35 AM   #4 (permalink)
Pig9r's Avatar
What's your current set up?
Old 04-16-2008, 11:30 AM   #5 (permalink)
Tors and Cat bypass and stock filter I have currently the correct Triumph tune but I still get the dreaded Decel popping. I had previousely had a PC3 but found out later I had 2 problems that made it run crappy.
I had the wrong triumph tune (thanks to a service manager who knows nothing about downloads) but have since gone to another dealer and had the proper tune downloaded from Triumph but I am also finding out that the bike has to be brought back to stock tune for the PC3 to work at it's best.
Old 04-16-2008, 11:56 AM   #6 (permalink)
Pig9r's Avatar
Find a dynojet dyno in your area and see how much they charge for a dyno tune. It is really simple with the PCIII.
Otherwise if you are getting popping on decel, add some fuel to the 0 throttle position row on the PCIII map. Others that have used canned maps have had to do the same.
Old 04-17-2008, 02:02 AM   #7 (permalink)
Wink
Thanks Pig9r
I have a plan now & have a good understanding I only wish my Rocket had good old carbs and simple idle adjustments instead of sensors,stepper motors,throttle position sensors yada yada yada.......
Cheers
Old 04-21-2008, 12:09 AM   #8 (permalink)
bkrbil's Avatar
I have the PCIII and just set up for install and Dyno at a Dynojet dealer...$300.00
2007 Triumph Rocket III, 2006 Triumph Speed Triple, 2004 Honda NRX1800 Rune, 2002 Honda GL1800 Gold Wing, 1998 Honda GL1500CT Valkyrie & 1988 Honda CBR1000 Hurricane
and my wife's
2005 Honda VTX1300R & 2004 Honda VT750CA Aero
bkrbil is offline   Reply With Quote
Old 04-21-2008, 12:31 PM   #9 (permalink)
For installation of the PCIII and a custom dyno tune, this isn't bad. You'll get better results if you get it tuned manually rather than with Tuning Link. Ask them if they're planning on a manual tune and how much that would cost.
dougl is offline   Reply With Quote
TBR Can & Power Commander SteveK Sprint Forum 19 12-13-2007 06:38 PM
Power commander tunes EasyWheelie Speed Triple Forum 6 02-20-2007 04:25 PM
power commander 14235 Speed Triple Forum 18 01-17-2007 08:15 PM
Power Commander? Anyone? Skiandclimb Daytona Deliberations 3 09-06-2006 12:58 PM
