Raddle At A Certin Rpm - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 03-30-2008, 12:06 PM   #1 (permalink)
I Have A Vibration At About Shift Time In All Gears I Tracked It Down To The Factory Did Not Put Gasket's In The Front Turn Lights As This Is The 05 R3 Ame I The Only Rocket Capt With This Problem Thanks
knapper is offline   Reply With Quote
Old 03-30-2008, 02:24 PM   #2 (permalink)
MikeRokkit's Avatar
You're not alone. I had the same problem.
MikeRokkit is offline   Reply With Quote
Old 03-31-2008, 09:56 PM   #3 (permalink)
Favourite Bike: Rocket III
Nightterror's Avatar
+1
I have the same problem and cant get them to just give me the gaskets. I have to bring the bike in for "inspection" and if they find something else it is chargeable.
NightTerror
"When you change the way you look at things, the things you look at change"
Nightterror is offline   Reply With Quote
rpm at 85 schwartzkm The Rocket Science Forum 23 10-10-2010 03:23 AM
Rpm Limiter eljohn3 Twins Technical Talk 15 06-25-2006 08:55 AM
Growl at 3.5 RPM Mr_Chips Trophy 10 05-07-2005 11:02 AM
what RPM at cruise? whoa Tiger Chat 3 12-28-2004 01:18 PM
Rattle @ 4k rpm spicoli Triumph SuperSports 5 10-12-2004 09:02 PM
