rear brake - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-30-2008, 11:41 AM   #1 (permalink)
rear brake
i have 7000 mi's on my 05 R3 the rear brake pads are starting to make a grinding noise when applyed is it something to let me know it needs replacing ? they look good
knapper is offline   Reply With Quote
Old 03-30-2008, 12:47 PM   #2 (permalink)
Favourite Bike: Rocket III
To your question, I would clean the rotor and caliper and reuse the pads. If the problem continues, then I would contact the dealer to check the rotor tolerances and install new pads.
TallRocket is offline   Reply With Quote
Old 03-30-2008, 03:49 PM   #3 (permalink)
Favourite Bike: 2006 Rocket III Classic
Pig9r's Avatar
Shine a light on the pads and see how much you have left.
Rear Brake... 805triple Speed Triple Forum 15 06-18-2008 07:58 PM
03 S3 rear brake help Pinballer Speed Triple Forum 0 05-26-2007 11:08 PM
Steel braided brake hose for rear brake midliferider Hinckley Classic Triples 4 05-20-2007 05:29 PM
Hot rear rear brake.????? rs_tt Maintenance & Workshop Talk 5 04-12-2007 12:55 AM
Correct position for brake lever on rear conical brake johnquinnell Classic, Vintage & Veteran 11 03-09-2007 04:42 PM
