Motorcycle.com
Old 03-25-2008   #1 (permalink)
Newbie
oil drip solved
i finally figured out what the problem was. after my last oil change i continued to have a very slow leak from around the front drain plug. thought i had over torqued it and stripped the threads or maybe i had bad washers. after trying several differant things, i examined the drain plug under a microscope and found a small crack in it. i have replaced it and now have no oil leak !
lklsnrrkt is offline   Reply With Quote
Old 03-25-2008   #2 (permalink)
Wow... that's interesting.. Always a first for every thing I guess..
Dave Arnold
'04 Rocket III
'01 Trophy 1200 (wife's ride)
La Vernia, TX
tbsrider2000 is offline   Reply With Quote
Old 03-28-2008   #3 (permalink)
Favorite Bike: The 2 I Own
If it's not leaking oil, are you SURE it's a Triumph? Maybe you better put the old plug back in! You must have bought a Japanese "knock-off" ! I loosened my drain plug up a bit just so I could "prove" it's a Triumph! Now it leaks and we're BOTH happy! Ha! Ha!
...and the Rocket's red glare
The jig is up.
The news is out.
They finally found me!
Styx... (Renegade)
Ride each ride like it may be your Last!
TRI-AL is offline   Reply With Quote
Old 03-28-2008   #4 (permalink)
Favorite Bike: 2005 Rocket III
RidinSunshine's Avatar
Talking
You sound like you are talking about HD! I am happy to say I have only had two leaks on my bike. There was something loose on mine that was leaking a little bit, but tightened it and no more leak. And my progressive shocks were leaking but the dealer replaced it under warranty and no more leaks there. Both where within the first 5,000 miles I think. I have 20,000 miles on it now and still no problems.
RidinSunshine is offline   Reply With Quote
oil drip lklsnrrkt The Rocket Science Forum 8 01-29-2008 08:34 PM
oil drip roller Sprint Forum 4 07-07-2006 03:21 PM
oil drip roller Speed Triple Forum 2 07-05-2006 07:30 PM
The Oil Drip... cafetbird Sprint Forum 7 11-21-2005 10:39 AM
Brake lights, oil drip triumphrdr Speed Triple Forum 9 10-08-2005 02:22 PM
