Rivco heel/toe shifter review.
OK, I finally got the H/T shifter installed yesterday. I ended up having to purchase a brake cylinder hone (thanks to another member’s suggestion). With the hone I was able to take off enough of the sleeve, and removed it evenly and smoothly, to allow the pivot bolt to slide in the hole.
So the install that should have taken me less than 30 minutes took me about three hours and required me to spend money on a special tool to complete the installation. I have tried all sorts of different adjustments but after the H/T install I seem to have trouble finding first gear when downshifting when I never had this problem with the stock shifter. I think part of the problem may be the unbalanced weight of the shifter not allowing it to click itself back in position after shifting. The unit is heavier on the heel area than the toe shifter. This is just a guess by me and I will continue to see what I can do with the adjustments available.
The other problem I found was getting the unit to be tight and without a lot of slop. I personally would like to see the shifter not have as much side to side play as it does. The instructions say that if there is a lot of play to add a second wave washer which I tried. But when I added a second washer it made the spacers now too thick and when I torqued the bolt it would not allow the shifter to rock up and down. So I had to remove the second washer and live with the excess play. I probably would be good if I had another washer that was only half as thick but these wave washers are already pretty thin to start with. It's amazing how much the thickness of one very thin wave washer makes. I may see what I can come up with, but I am kind of disappointed that I should have to do this.
Would I buy this H/T shifter again? After all of the fabrication I had to do and the fit not as good as I would have liked probably not. I will say the couple of people I talked to at Rivco were very nice and helpful, I am just not in love with their heel/toe shifter.
Doglanta (Ken)
2005 Triumph Rocket III
2007 Triumph Speed Triple
