Also since you have the R3T, I wonder if the fuel gage set up is the same? Since the fuel gage is part of the cluster on top of the fuel tank, I was wondering if that cluster comes off the top of the tank and the fuel "rod" adjustment is done there instead of from the bottom of the tank like the other variations of the R3?
Since this tank is supposed to get about 40 miles to the gallon and you have a 4.9 gallon tank, I would also think that your fuel range should be close to the 195 mile counter on the fuel "distance to empty" counter. So it would seem there is some kind of adjustment that should be able to be done, just hope that your dealer knows how to do it as the procedure may be different than on the "normal" R3.
Dennis
