Coolant Change - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.comHonda PowersportsNew BonnevilleMotorcycle.com Classifieds!
Old 02-12-2008, 04:01 PM   #1 (permalink)
Favourite Bike: 2005 Rocket III
Other Motorcycle: 2001 Roadking Classic
Extra Motorcycle: 1999 Busa
Question Coolant Change
It's been three years since I've changed or flushed the fluid in the coolant system on the 05. I do check the levels once and awhile to make sure it's full. Riding V-Twins for so long maintaining a water cooled system on a "bike" is new to me . Is this a know brainer or are there procedures i should be aware of ....Thanks in advance Rick
TRIIICK is offline   Reply With Quote
Old 02-13-2008, 12:44 PM   #2 (permalink)
All I did was disconnect the hose at the the bottom of the engine, drain all the fluid out, reconnect, refill, run the engine a bit, check level, top off, run engine...check level...top off...until it stayed full. About as easy as changing oil. I also bought an oil temp oil cap from newr3.com just to keep an eye on things.
Ugarte is offline   Reply With Quote
Old 02-14-2008, 12:28 PM   #3 (permalink)
Thank U...!
Coolant change help DKScully Triumph SuperSports 7 08-16-2007 05:27 PM
Brown coolant??? Coolant change?? Suncoast Sprint Forum 8 02-05-2007 12:51 PM
Coolant change Galesa Sprint Forum 4 09-15-2006 10:09 PM
Coolant change whistler Maintenance & Workshop Talk 2 06-12-2005 11:08 PM
