I don't know if this will help, but it's worth mentioning. When did you last get tires, and has it done this thru 2 different sets? i ask because i had this horrible vine on my speedmaster in 2nd gear only and at a certain RPM, about 2k if i recall. I spent months trying everything you can imagine and asked everywhere and the issue stumped me and all others. It began a few hundred miles after a new set of tires. Same tires as were stock...metzelers. Turned out the front tire was defective. Who could have imagined i would get a cyclic type vibration that only happened in second and only at a specific rpm from a defective tire? Your vibes are a bit different, but i would suggest you take a serious look at the possibility of a defective or ill wearing tire.
I couldn't list the things i tried even including even replacing wheel bearings.The list is VERY long. I'm sure the dealer wouldn't have had a clue either. just some food for thought. And by the way, if the dealer is telling you this is normal, ask him why other R3's don't do this and contact triumph directly. But remember, if it IS a tire and not the original that came with the bike, they are not responsible.
