British Motorcycle GearSoupy's PerformanceTriumphPerformanceUSABikeBanditMotorcycle.comTriumph Detroit
GoFreeCreditReport
Old 01-21-2008   #21 (permalink)
Originally Posted by Pig9r View Post
I did both Tuneboy and PCIII. To do a good complete dyno tune with Tuneboy takes a good 8 hours and that is just for fueling. Ignition I would imagine would take just as long. PCIII remaps on the fly so it is much quicker, with TUneboy you have to stop, make changes, load the tune then do another run.
I wanted a dyno tune but didn't want to spend all the dough for a dyno tune with Tuneboy. So I took a Tuneboy tune (20050_3) that had some timing changes already done and loaded it into my bike. I then hooked up a PCIII and had a custom fuel map made. I unhooked the PCIII then imported the PCIII custom dyno map into the Tuneboy tune that was loaded into the bike. I then reloaded the new tune into the bike. All with just a little over an hour on the dyno. With Maddog exhaust, no cat, and triple K&Ns I got 146hp and 148ftlbs torque with just the 20050_3 tune. After the PCIII dyno tune I got 152 hp and 155 ftlbs. Plus it was much smoother.
One thing that Tuneboy can do that nothing else can to make the bike go faster is remap timing. Triumph limited power in 1st thru 3rd gears by retarding the timing. Just by copying the 4th and 5th gear maps to 1st, 2nd and 3rd, in Tuneboy it makes a big difference.
Another thing the Tuneboy can do is remove the rpm and speed limiters. But if you want to go 170, forget it.
dougl is online now   Reply With Quote
Old 01-21-2008   #22 (permalink)
GREAT INFOE GUYS! what kind of speed with tuneboy 150mph? also is the tuneboy easy load or download? im not very computer smart.
lowes is offline   Reply With Quote
Old 01-22-2008   #23 (permalink)
Favourite Bike: 2006 Rocket III Classic
Pig9r's Avatar
Tuneboy can be tricky if you are not computer savy. I would find someone who is to help out. You need a lap top or a way to get a usb cable from your desktop to your bike.
Doug why don't we get a commission from Wayne for this??
Old 01-22-2008   #24 (permalink)
Originally Posted by THE MAN View Post
150 easy I would say I have Jardines,triple filters,Nevs cams and a good tune.My bike went 167rwhp that australian which = about 163 US rwhp and 165.34 ftlbs
I have had my bike at 6500rpm in top gear and it was still pulling.Speed was some where near 265 to 270kph
Nev cams are clearly a big factor in big HP. How much did it run you to buy and install? That must be a new world record for the Rocket (168 mph)! You must have Tuneboy to override the stock speed limiter, which is set at 218 kph (135.5 mph).
Old 01-22-2008   #25 (permalink)
GREAT INFOE!!!! 135mph stock but do i understand you right that with tuneboy 150mph can be reached?
Old 01-22-2008   #26 (permalink)
Nev done all the workit cost me just over $3000 Aus and a couple of days traveling to and from Bairnsdale to Adelaide.
Here's another annoying question from someone who couldn't get the spark plugs out.
When you get different cams from Nev, do they come on a cam shaft or do you take the old cams off and hammer on the new ones?
Old 01-23-2008   #27 (permalink)
Pig9r's Avatar
Lowes- you can fit the triples under the claw cover without modifying it.
http://www.r3owners.net/showthread.php?t=1102
Old 01-23-2008   #28 (permalink)
tune boy
Originally Posted by dougl View Post
Who did you race to determine that?
Please tell me how tune boy will make my bike faster than just pc3,...Thanks
trumpete is offline   Reply With Quote
Old 01-23-2008   #29 (permalink)
From what i have read you can raise the rev limiter for more top end speed.
Old 01-23-2008   #30 (permalink)
Favourite Bike: 06 Speed Triple
Other Motorcycle: 05 Rocket III
Extra Motorcycle: 03 Warrior
Just a word of caution here. If you are really going to make your Rocket run over 150 /160 You might want to look at the aero package. I've got the big clearview screen on mine and have run it up to 142 ( GPS reading ) and had to keep as much weight as far forward as possible so feel even some what stable. Fly screen or some kind of mini fairing would probably be best. They limited the top speed at 140, Probably because the ergonomics of the machine where so unstable at speeds above that. Bottom line, the R-3 was built to be a comfortable power cruiser. Just don't think it was made to run at high speeds or it would have come with the missing 6th gear. But if this is your desire, first thing I would do would be Hagon Nitro rear shocks and progressive fork springs.
Life is a highway Enjoy your ride
Photo Album
rockt3 is offline   Reply With Quote
104+ RWHP Bonneville(SBTP) Bonnie1000th Twins Technical Talk 15 07-30-2007 09:34 PM
How much rwhp does the speed triple make? roadkill Speed Triple Forum 19 02-09-2007 10:56 PM
125 rwhp, 77 rwtq...thanks Devious2xs TightTL Speed Triple Forum 21 01-18-2007 07:02 PM
What are the real specs about rwhp for a standard R3 ? MadRock The Rocket Science Forum 9 11-29-2005 07:54 AM
2005 ST RWHP viper3256 Sprint Forum 17 06-01-2005 06:18 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
