JardineProducts.comAnnitori DistributingSoupy's PerformanceMotorcycle.comTriumphPerformanceUSATriumph DetroitBikeBandit
Old 01-21-2008   #11 (permalink)
Favourite Bike: 2005 Rocket III
TRIIICK's Avatar
Other Motorcycle: 2001 Roadking Classic
Let me introduce you to my little friend.....FREEDOM
TRIIICK is offline   Reply With Quote
Old 01-21-2008   #12 (permalink)
Originally Posted by busajack View Post
Hey Lowes,all it takes is money.Other than a blower you got all your gona get.Thats why the posts about other bikes.Sorry for the hi jackin..A super moderator WOWOWOW
Superbikes are mentioned for perspective.
Anyway, If he buys the Tuneboy, he can put a custom tune in (decel variant of 20050_2) that will open the secondaries and give him about 13 ft. lbs. more of peak torque. I got 140 hp at 6300 rpm and 150 ft. lbs. at about 2700 rpm.
If he puts on the triple K&N's, he can use 20050_3 with Pig9r's PCIII overlay - he'll definitely gain peak HP. This is all for about $500, mostly for Tuneboy - K&N 2780's are cheap. I had triple Unifilters on with the 20050_3 tune. It was probably a bit faster at 6000 rpm but I don't spend much time in that range. Remember, the difference between 140 and 150 hp is only 7%.
Rebuild the engine with cams and high compression pistons? Like you said, you could spend a lot of money.
dougl is offline   Reply With Quote
Old 01-21-2008   #13 (permalink)
what is a pc3 overlay?
lowes is offline   Reply With Quote
Old 01-21-2008   #14 (permalink)
The Tuneboy software allows you to apply a PCIII fuel trim map (generated by dyno tuning a bike fitted with a DynoJet PCIII) to a tune which you can download into the Rocket's ECU using Tuneboy. It provides a way to fine-tune custom dyno tunes done by Wayne at Tuneboy on Rockets with various exhaust (like yours, for example) and intake configurations.
Old 01-21-2008   #15 (permalink)
more power
Triple kn filters mod is the best bang for the buck (90$). Remove secondary plates (free) pc3 (250$) dyno tune (200$ for me) Tune boy for lots of other stuff that doesnt make it go faster!
trumpete is offline   Reply With Quote
Old 01-21-2008   #16 (permalink)
dougl, did you dyno the bike on the same dyno before you did mods ?
travelguy is offline   Reply With Quote
Old 01-21-2008   #17 (permalink)
Who did you race to determine that?
Old 01-21-2008   #18 (permalink)
No, when I put the Uni's on, I brought it to a Honda dealer to dyno it. I think they got 132. This was weird because it definitely felt stronger at the high end than with Wayne's 20050_2. They also got an A/F off scale. The consensus was that the kid running the dyno at Honda didn't know what he was doing.
The next day, someone in Oz had a Unifilter fire and I remove them from my bike,
Later, I took it to my dealer, who is a DJ center and has been doing this for decades. With the TOR's/Cat bypass and Wayne's 20050_2, it ran 140 hp and 150 ft lbs, on the second run. Since he did this for free, I didn't ask for more runs.
Then I had him load the Triumph tune for that exhaust. As I remember, the peak HP was maybe 1 or 2 lower but there was a big dip in peak torque (about 12 ft lbs) from the closing of the secondaries in the stock tune.
I drove it home with the stock tune in and honestly couldn't tell the difference. I like my modification of Wayne's tune because it eliminates the popping on decel.
It would be helpful if everyone who does sh!t to their bikes would get official 1/4 mile times so that everyone else would know what they're getting for the big bucks.
Old 01-21-2008   #19 (permalink)
Smile
After reading all the good post what do must people do tuneboy or pc3? will i get more top end speed with the tune boy?
Old 01-21-2008   #20 (permalink)
Favourite Bike: 2006 Rocket III Classic
Pig9r's Avatar
I did both Tuneboy and PCIII. To do a good complete dyno tune with Tuneboy takes a good 8 hours and that is just for fueling. Ignition I would imagine would take just as long. PCIII remaps on the fly so it is much quicker, with TUneboy you have to stop, make changes, load the tune then do another run.
I wanted a dyno tune but didn't want to spend all the dough for a dyno tune with Tuneboy. So I took a Tuneboy tune (20050_3) that had some timing changes already done and loaded it into my bike. I then hooked up a PCIII and had a custom fuel map made. I unhooked the PCIII then imported the PCIII custom dyno map into the Tuneboy tune that was loaded into the bike. I then reloaded the new tune into the bike. All with just a little over an hour on the dyno. With Maddog exhaust, no cat, and triple K&Ns I got 146hp and 148ftlbs torque with just the 20050_3 tune. After the PCIII dyno tune I got 152 hp and 155 ftlbs. Plus it was much smoother.
One thing that Tuneboy can do that nothing else can to make the bike go faster is remap timing. Triumph limited power in 1st thru 3rd gears by retarding the timing. Just by copying the 4th and 5th gear maps to 1st, 2nd and 3rd, in Tuneboy it makes a big difference.
104+ RWHP Bonneville(SBTP) Bonnie1000th Twins Technical Talk 15 07-30-2007 09:34 PM
How much rwhp does the speed triple make? roadkill Speed Triple Forum 19 02-09-2007 10:56 PM
125 rwhp, 77 rwtq...thanks Devious2xs TightTL Speed Triple Forum 21 01-18-2007 07:02 PM
What are the real specs about rwhp for a standard R3 ? MadRock The Rocket Science Forum 9 11-29-2005 07:54 AM
2005 ST RWHP viper3256 Sprint Forum 17 06-01-2005 06:18 PM
Harley Davidson Suzuki GSXR Ducati Forum Kawasaki Forum
V-Rod Forum GSXR Forum Ducati Monster Vulcan Forums
Harley Forum Suzuki SV Honda 600RR Kawasaki ZX Forum
Buell Forum Yamaha R1 Honda 1000RR Kawasaki ZX-10R
KTM Forum Yamaha R6 Honda Fury Forums Triumph Forum
Victory Forums YZF-R6 Forum Honda Goldwing Triumph 675
Can Am Spyder Aprilia Forum Sportbikes Forum BMW S1000RR Forum
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
